Old 11/21/08, 10:02 PM
Erol Kartal Erol Kartal is offline
Please Note: Erol Kartal is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Attic Insulation
I've been reading about the advantages of insulating both the unfinished attic floor and rafters in areas of hot sunny weather. Not that Chicago compares to Fresno but I have never once seen insulation between rafters. Is it trapped humid air between the insulation and sheathing that makes it a bad idea for the midwest?
Thanks
Old 11/21/08, 11:33 PM
Default Re: Attic Insulation
Erol...
I've seen it in Waukegan before where they've converted an attic space into a living area. There should still be an air gap between the sheathing and the insulation, I believe 1" is recommended. If there are soffit vents as well as ridge vents, you should be good to go.
Reflective Insulation
Jeff
Old 11/21/08, 11:38 PM
Darren Spencer Darren Spencer is offline
They are actually changing the way it is installed and it is the air gap that creates the problems. If a insulation is installed where the material can not reach the dew point the chance for condensation is zero.
Old 11/22/08, 10:01 AM
jhugenroth jhugenroth is offline
Please Note: jhugenroth is a non-member guest and is in no way affiliated with InterNACHI or its members.
Originally Posted by ekartal View Post
Not that Chicago compares to Fresno..
Yeah, at least 100 degrees here is bearable! (It's a dry heat)
I've never seen insulation in both places yet.
Old 11/22/08, 10:12 AM
ldapkus ldapkus is offline
I've seen one new construction home that was spray foamed.
Old 11/22/08, 10:51 AM
David P. Valley's Avatar
I see 80% of the homes I inspect, improperly insulated. I simply give them a link to my website...
http://www.masscertifiedhomeinspections.com/?D=47
Building Science- research from respected sources Brian A. MacNeish Ancillary Inspection Services & Additional Topics 17 7/12/11 6:31 AM
Poly being applied to Basement walls dvalley Interior Inspections 40 11/24/09 10:49 PM
Is it important to get ceiling joists 16" OC? Nathan W. Swilling Structural Inspections 9 1/11/08 10:10 PM
New Old Insulation rcooke Canadian Inspectors 1 12/13/06 5:25 PM
