This is from a 1958 home. Asbestos possibilty?
Looks like loose fill cellulose...not a problem.
I've never heard that absestos was used as loose fill residential insulation.
I would be surprised if it was asbestious . Did you take a sample . Asbestous an water make like almost bread dough and will dry out to a very weak ball if this is the shpe you leave it in. Can be broke apart . We used to make castles and do geography with it when I went to school. You can not do this with rock wool and rock wool is more lumpy like shown in picture . Roy Cooke sr |
I agree, that looks like rock wool (fiberglass) insulation to me too. Asbestos looks like this, not that that you can see much though:
Attachment 4942 Last edited by mboyett; 4/9/09 at 9:38 PM.. |
http://www.naima.org/pages/resources...html/N016.HTML Fiber Glass Insulation Is Made From Sand or Recycled Glass
Roy Cooke sr |
Another type of insulation to be aware of is Vermiculite Zonolite was one type
Some look like small cubes with 1/4 inch± with a shiny side like MICA some other was smaller like 1/8± grey white both are very lite and some have been known to contain asbestos http://www.gov.mb.ca/labour/safety/pdf/bltn245.pdf I believe this has been talked about before on this BB but it is worth while to bring it up for the newer HIs. Roy Cooke sr |
If a picture is worth 1,000 words.
The only ones of value are, "have it TESTED", if you want to be certain. With that said photo does look like dusty old rockwool. All the loose fill asbestos I've seen is pelletized chunks, with fibers in all directions, very obvious. http://www.dmme.virginia.gov/De/energybook/hbchap3.html http://www.eere.energy.gov/consumer/your_home/insulation_airsealing/index.cfm/mytopic=11510 ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good Last edited by badair; 8/7/06 at 7:48 AM.. |
ccbrands1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
based on the pic, it could go either way.
rock wool or cellulose. dont think its asbestos. touching it would confirm. |
Touch it, taste it, breathe it, wait 20 years to see if asbestosis or mesothelioma occurs, if not then it's not asbestos. Pretty simple, albeit slow, protocol.
MBoyyet;
Your good, I did just that, I touched it, installed it, waited 20 years and still here so it was not Asbestos, right? Wrong. Worked and installed Zonilite also and not Zolilite. Still here. Roy is correct in his post to help us distinguish what had asbestos content and what did not. The picuture showed here is blown or bag cellulose. As far as I know back in 1963 when my father had me on the job, most attic insulation was wood shavings, do you believe that. I do. I use to fall asleep installing it. ha. ha. That usually was reflected in my pay. 50 cents an hour, slept for two. Man that hurt. ha. ha. Marcel |
And how much asbestos have you seen . I have installed by the bag full wet it down to put on jacket heaters ( before electric water heaters ). Installed it on water heaters before they came insulated . . Forty years ago we had no fancy thermometers . My hand did the job then and does the job now . Motor if I can hold my hand on it and count to ten it is not to hot . Saw some motors I had to count fast . New is not alway better . dead pater drop your thermometer or leave it at last inspection you are out of luck . My hand works for me . My computer continues to function fine it is seven inches long yellow wood frame and has a brown delete button on the end . Been working great for 50± years . Roy Cooke Sr |
| Attic Insulation Identification | mcyr | Interior Inspections | 0 | 5/26/07 9:33 AM |
| Spray Foam to the Rescue ? | mcyr | Structural Inspections | 3 | 3/27/07 7:29 PM |
| New Old Insulation | rcooke | Canadian Inspectors | 1 | 12/13/06 5:25 PM |
| Home Warranty Attic Insulation Question | jhawes | Canadian Inspectors | 2 | 12/4/06 1:54 AM |
