Is there a minimum size on attic space before it needs access?
Conditionally:
If 30 inches of unobstructive headroom can be provided and if the building has compustible ceiling or roof construction. |
As stated...
Attic accesses are required for any attic that has a clear ceiling height of 30 inches or more, and the opening needs to be a minimum of 22 inches by 30 inches in size. Note that one dimension is 22 inches instead of 24 inches - the building codes have made this adjustment so that access holes will fit between commonly used roof trusses, which are usually on 24-inch centers. Here again, the codes don't typically specify inside or outside access. |
| Attic wall separation from interior living space | sglick | Interior Inspections | 4 | 5/27/07 8:47 PM |
| Spray Foam to the Rescue ? | mcyr | Structural Inspections | 3 | 3/27/07 7:29 PM |
| Vent trap in the attic space? | kshepard | Inspecting HVAC Systems | 9 | 12/7/06 1:00 AM |
| New Attic Storage Space | jhagarty | Structural Inspections | 8 | 7/14/06 8:20 PM |
