ecoutu is a non-member guest and is in no way affiliated with InterNACHI or its members.
With the recent heat wave throughout the country and some of the attics I've been in the past few days, I'm wondering if anyone has a rule of thumb for how much difference between outside air and temperature in the attic is acceptable. If it gets too hot in the attic, does it matter?
I think he was able to get back down out of the attic but died in the home . Any one have more information on this . Roy Cooke sr |
Most thermostats for attic fans have a maximum setting of 140°F. That is the same setting I use for determining whether or not I go into the attic to any significant distance. It's not hard to explain heat-related deaths to Clients; just save all the newspaper stories that appeared in papers this month. Use that third-party reference (the manufacturer's maximum thermostat setting) and pull out some stories about heat-related deaths, and recommend more ventilation for the attic, and you'll probably be okay. Charge a reduced fee (I charge half my original inspection fee) to go back out and inspect things that could not be inspected at the original inspection, or recommend further evaluation by a qualified roofing contractor, who, hopefully, will provide them with additional information about high attic temperatures, as well as options for installing additional ventilation. NACHI 2005 U.S. Member of the Year
I heard 20 degrees from outside to inside.
"Be Proud of Your Home, Go With Pride!" 'Not just a Home Inspection, but an Education' Pride Property Inspections provides professional Home Inspections throughout Tucson and Southern Arizona including Pima, Cochise, Pinal, Santa Cruz, Graham counties. |
cfuoco is a non-member guest and is in no way affiliated with InterNACHI or its members.
This was one from last week for me.
lewens is a non-member guest and is in no way affiliated with InterNACHI or its members.
Inadequate attic ventilation will result in a reduction of the life expectancy of the roof covering, if asphalt based. Ideally the attic temp should be as close as possible to the outside temp. That is close to impossible on a hot day. If the roof is exposed to the sun on a hot day I will not even walk it, the potential for damage is too great.
Larry |
briddle is a non-member guest and is in no way affiliated with InterNACHI or its members.
I heard there is usually about a 40 degree difference. Can't remember where I heard it though.
![]() This was in an uninsulated garage wall facing west as the sun was going down, I don't know what the attic temperature was, probably the same or a little warmer. 150-160 are not uncommon when its 115 in the shade here. Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
150 is very common here with proper ventilation and the hot sun bearing down on a dark roof!
i would not enter an attic much hotter than 120 degrees because it is difficult to breathe with a resperator on
If it's hotter than 80°F, Ms Margarita and Dr Cuervo head to the beach, not an attic!
If it's hotter than 80°F, Ms Margarita and Dr Cuervo head to the beach, not an attic! If that is the case, you must not be inspecting the roof and/or the attic's too often. ha. ha. Marcel |
| Supply Plenum Mounted High in Attic | Skip Erwin | Inspecting HVAC Systems | 6 | 4/7/07 10:07 AM |
| Spray Foam to the Rescue ? | mcyr | Structural Inspections | 3 | 3/27/07 7:29 PM |
| Attic Inspection | rbritton | Electrical Inspections | 19 | 8/2/06 2:58 PM |
| Attic Temperatures Can Pose Serious Risks | jtedesco1 | Interior Inspections | 4 | 4/2/06 10:17 AM |
