Old 10/5/09, 4:00 PM
Ben J. Gromicko's Avatar
Ben J. Gromicko Ben J. Gromicko is offline
Default Attic Ventilation SOP Requirement
attic-ventilation-standard-practice-requirement-img_0243.jpg attic-ventilation-standard-practice-requirement-img_0020.jpg attic-ventilation-standard-practice-requirement-img_0022.jpg attic-ventilation-standard-practice-requirement-img_0228.jpg attic-ventilation-standard-practice-requirement-img_0230.jpg
According to Res. SOP
2.9. Attic, Ventilation & Insulation
I. The inspector shall inspect
B. the ventilation of the attic spaces
C. mechanical ventilation systems;
II. The inspector is not required to:
F. activate thermostatically operated fans.
Is that confusing to anyone?
Because the SOP requires me to inspect the attic ventilation AND the mechanical ventilation systems, a client might say my inspection includes activating the thermostatically operated fan.
In law, if there is any confusion, the consumer wins.
BEN GROMICKO
InterNACHI Director of Education
Now That You've Had a Home Inspection" Book
Find an InterNACHI certified North Carolina Home Inspector (and anywhere else in North America)
Old 10/5/09, 4:04 PM
James H. Bushart's Avatar
Default Re: Attic Ventilation SOP Requirement
How can it be "confusing" when it specifically states that the inspector is not required to activate thermostatically operated fans?
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
Old 10/5/09, 4:12 PM
If a consumer thinks that the mechanical ventilation system in an attic includes a roof fan, then there is confusion. And when there's confusion, the consumer legally is protected (or wins).
BEN GROMICKO
Old 10/5/09, 4:20 PM
rmaday's Avatar
rmaday rmaday is offline
Please Note: rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
Ditto.
Just like other exclusions and limitations.
Old 10/5/09, 5:46 PM
Are they talking about a remotely installed thermostat or integrally built-in with the exhaust fan set at a pre-set temperature.
If it is remote, then what is the difference between that and using normal operating controls on a furnace thermostat?
What if I use a simulated heat source (my lighter) to activate the thermostat? Then I did not touch it and know if it worked, right.
Old 10/5/09, 5:58 PM
Hard to activate a thermostat controlled attic fan when the temp is in the 20's. Most of the t-stats don't go much below 60, if that.
Abraham Lincoln
Old 10/5/09, 6:13 PM
Blaine, you got to use this one;
Line voltage 0-100
Old 10/5/09, 6:28 PM
Actually, Marcel, I try not to inspect when the temperature is below 60. Just too darn cold for me!
Abraham Lincoln
Old 10/5/09, 6:35 PM
Still looking for one for my area Blaine 0-85.
Poured concrete last Winter at -8 and that was pushing my limit.
My blood stops flowing at below 0
Old 10/5/09, 7:11 PM
James F. McKee's Avatar
I think I'd be pretty ticked off at an inspector that started fooling around with the thermostatic controls on the power vent in my attic and have no problem telling a client that is not my job....
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 10/5/09, 7:15 PM
Haven't seen one yet so I guess it is not a problem Jim.
Usually, everything is frozen up there anyways.
Old 10/5/09, 7:21 PM
yes Marcel it is a regional thing for sure, different parts of the country they are very handy....mine runs a lot in the summer months....it has a thermostat and a humidistat, but you will never hear it come on between September and may....
Jim Mckee
Amherst, Ohio
Old 10/5/09, 7:27 PM
You know Jim, this makes me think.
Would not having the proper insulation value and the proper 1 sf. of free air ventilation per 300 sf of attic space and a natural balance of eave and soffit vents off-set the cost of the energy usage and maintenance required for those fans to begin with?
Just talking out loud.
Old 10/5/09, 7:33 PM
I had that same conversation with my roofer two years ago when this one was installed Marcel...and it sure was borderline on this house, but a number of years back i owned a split level with great temperature differences from level to level...and decided to install a couple of power vents....solved the problem in a heart beat and saved a bundle on heating and cooling...I think it greatly depends on the design of the structure....jmo...
Jim Mckee
Amherst, Ohio
Old 10/5/09, 7:41 PM
I guess going back to checking an exhaust fan in the Attic, I would personally just note that one was observed and not inspected for whatever design it was intended for. The hell with the fan.
Mold question? ccurrins Interior Inspections 35 1/23/09 11:55 AM
Way More Intake To Supplement Minimal Exhaust Ventilation? Ed Fako Exterior Inspections 1 12/19/08 6:07 PM
Is inadequate roof or attic ventilation a defect? gliebig Exterior Inspections 85 1/16/08 6:56 PM
Attic ventilation requirement rray Inspecting HVAC Systems 42 4/23/06 11:44 AM
