Old 5/25/07, 12:00 PM
sglick sglick is offline
Default Attic wall separation from interior living space
Today's inspection. I have a interior furnace closet that is separated from the attic with fiberglass insulation in the wall but no drywall. Does it have to be separated with drywall? The insulation is Kraft paper backed and there is not any combustion venting unless they think air passing through the fiberglass is good enough, but that's all another story. One year old town home.
Old 5/25/07, 12:40 PM
Jeffrey R. Pope's Avatar
Default Re: Attic wall separation from interior living space
Combustion air vents must be unobstructed.
I don't have my references in front of me, but I know the UBC requires a 1 hour separation (drywall or sheet metal) at the closet ceiling. I believe the IRC does as well, but I can't verify that right now. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 5/26/07, 8:00 PM
homebild homebild is offline
The kraft facing on fiberglass insulation is flammable and DOES need to be protected by at least 1/2" drywall or other type of approved wall covering as a fire separation.
The Energy Codes also require that if this fiberglass insulated wall is exposed to the interior of the attic (as would be a 'knee wall") then it wust be sealed with and 'air barrier' on the attic side of the insulation.
See section R315 for "Flame Spread and Smoke Density" ratings under the 2003-2006 IRC Codes...
And section N1102.4.1 under the IRC 2006 and IECC 2006 section 402.4
Old 5/27/07, 8:16 AM
arussell arussell is offline
Please Note: arussell is a non-member guest and is in no way affiliated with InterNACHI or its members.
Seth
As previously posted the insulation must be covered with 5/8" drywall (considered fire rated) and if it's in a closet the unit needs make-up air, usually with louvered door.
alan
Old 5/27/07, 8:47 PM
Thanks everyone you confirmed everything for me.
VIDEO--Bowed Basement Wall, Cracks etc john bubber Structural Inspections 75 7/21/08 5:25 PM
Newbie here with a slab "standards" question Robert Young, #3 Structural Inspections 17 4/10/07 10:48 AM
Spray Foam to the Rescue ? mcyr Structural Inspections 3 3/27/07 7:29 PM
Attic Space lmills Interior Inspections 2 10/3/06 3:01 PM
Wiring/Plumbing through separation wall Tab M. Wilcox Interior Inspections 7 9/10/06 11:03 AM
