Old 9/15/09, 10:15 AM
Gary Spencer Gary Spencer is offline
Please Note: Gary Spencer is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Baseboard moisture level at a spot in basement
The following is a quote on an inspection report for a Tri level home built in 1975.
"An elevated moisture level was noted in the furnace room at the baseboard. A moisture meter indicated a moisture level of approximately 18% in the baseboard near the watershutoff velve. Previous leakage from a humidifer was noted, but no moisture was visible at time of inspection."
The furnace room is located along the inside wall, is finished, there were no other notes about moisture and the spot is located about 12" from the floor drain.
What, if anything should be assumed about this statement?
Find an InterNACHI certified Maine Home Inspector (and anywhere else in North America)
Old 9/15/09, 12:52 PM
Default Re: Baseboard moisture level at a spot in basement
Ask the person that wrote it.
It may be just an FYI and monitor situation.
Larry Kage, CMI
231 929 3525
Old 9/15/09, 1:47 PM
David A. Andersen's Avatar
Sounds like a condensation issue.
As Larry posted, ALWAYS call your inspector FIRST!
He/She was there, we weren't.
BPI# 5015804
IR level 0ne V/S Building Science cbottger Ancillary Inspection Services & Additional Topics 38 8/21/07 11:09 PM
bbbb mcyr Structural Inspections 1 8/19/07 10:26 PM
gutter downspout to basement drainage system David Paterson Exterior Inspections 2 12/18/06 6:27 PM
Permanently elevated moisture levels beneath basement slab: why? kshepard Interior Inspections 25 7/7/06 7:55 PM
