My pic. is not good...I didnt get a isolated picture of the actual
area !!!! It looked like a small bulge as the baseboard met the corner. The baseboard not was cracked...it just was not straight over about a 16 inch area. When I replaced the baseboards in my own house...I noticed the it was not perfectly straight.... I need possible causes for my report. I didnt see any strurctural or water problems.
| Need a home inspection in Massachusetts? Check out InterNACHI's listing of Massachusetts certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
"The wall in the *LOCATION(rooms-interior)* is slightly bowed. Achieving absolute perfection while building a home is impossible and slight imperfections are normally only aesthetic issues that may never be noticed by guests. Sometimes, however, a defect crosses the line into a poor workmanship issue and only you, the buyer, can make that determination. We can elaborate, but you should have the builder or seller comment on the reason for the defect and you may wish to have it repaired."
When involved in building,
The critical question to ask.... was of the Foundation Contractor.... Will you Guarantee the "Square".? Differential in the square of the foundation will impact all costs as you go up... Framing Drywall Roofing etc..... Cutoff Waste.... Costs Money.... Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
Where is the upper level plumbing drain?
Should never be in an exterior wall.
But is done on exterior basement walls with insulation stuffed behind. Often creates bulge in drywall as framing does not fully compensate for drainage piping. Noted in basements many times. Part of what I do.
By the way, not trying to be agaisnt anyone, just my observations over the years. Last edited by atimmermans; 5/6/11 at 11:56 PM.. Reason: not fully explained |
I don't believe this is a basement .
galaxyhomeinspections.com An amateur built the Ark ! Professionals built the Titanic ! |
Thanks everybody
so.....
.... what was the identified and resolved issue Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
I wrote it up as a pipe in the wall....( going around it caused the bulge)
On the exterior wall in the same place...there was a clean out... So it looked like it was the drain for the upstairs bath tub and shower. But I added that opening up the drywall was beyond the scope of the Home Inspection and they could seek the services of a licensed Building Contractor to evaluate it. David |
| Baseboard efficiency question | thalpin | Thermal Imaging, Infrared Cameras & Energy Audits | 14 | 2/2/10 12:23 AM |
| Saturated Window Facing Trim | jevans | Exterior Inspections | 1 | 9/24/09 6:49 AM |
| Baseboard heater + Thermostat Question. | jkogel | Electrical Inspections | 3 | 5/7/08 10:30 AM |
| Answer to a common question about GFCI's | jtedesco1 | Electrical Inspections | 4 | 1/12/06 9:29 PM |
