An ongoing issue, realtors adding a "basement bedroom" without required egress as a bedroom in the listing. I do explain the egress requirements to the clients during the inspection and in the report. What I do not understand is how the agents are allowed to list these basement rooms as bedrooms. Also have the same issue on occasion with older townhomes that have a center "bedroom" with no window. How are other inspectors reporting these unqualified bedrooms?
| Find an InterNACHI certified Missouri Home Inspector (and anywhere else in North America) |
It's not our job to qualify or disqualify a bedroom. We are looking for defects. Lack of egress would be one, so I would note it and go on. Let the appraiser define if it's a bedroom or not.
Exactly...if it has a closet and can be used as a bedroom, I report the lack of egree as needed.
Report the lack of emergency escape or rescue window or exterior door opening for emergency escape and rescue.
It is not your job. That is for an Appraiser or Building Official to determine what is Non Conforming or Not Code. Report on Safe and Sanitary conditions.
Have you ever seen the aftermath of basement bedroom fire and removed the bodies of children from the area. I will continue to REPORT IT EVERY TIME I found one.
Take this free online mini course on egress: http://education.nachi.org/show.php?course_id=29
Take this advanced video course on egress: http://www.nachi.org/advancedcourses.htm (scroll down). Download free booklet / course material: http://education.nachi.org/coursemed..._Materials.pdf Nick Gromicko, Certified Master Inspector Find a Home Inspector "Just as iron sharpens iron, one man sharpens another." Proverbs 27:17 |
You would not want to identify a room as a bedroom that had no (or insufficiently sized) window, no source of heat or opened into a garage. James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 |
Clarification: The finished basement section in all of my reports have a Basement Bedroom Requirements section. I summarize the current basement sleeping room building and safety standards derived from the IRC code. Note: The word code is never in my reports. The point of the post is to expose the conflict between a realtor and/or appraiser evaluation of a bedroom and our knowledge of the egress requirements. It would be beneficial if the home listings truly reflected the actual number of legitimate bedrooms.
Here the comment I often use :"I am not a code inspector and determining if your home meets current local code falls outside InterNACHI's Standards of Practice. However, it appears to me that this home may have an emergency exit safety issue in the basement bedroom. I recommend that you contact the local building code official for more information and consider addressing this issue if you plan on using the room as a sleeping area." This was taken from Nachi
Jeannot |
Remember, it's not what you say, it's how you say it. Mark Nahrgang www.DaytonSpringfieldHomeInspector.com www.HeyMark.info Home Inspections for Springfield, Dayton, and surrounding OH areas. |
| Site grading and drainage | wdevries | Canadian Inspectors | 5 | 10/6/09 10:23 PM |
| Options in selecting materials for basement construction | wdevries | Canadian Inspectors | 2 | 8/4/08 1:30 PM |
| Legal: Buyer points blame at sellers when basement repeatedly floods. | gromicko | Legislation, Licensing & Legal Issues for Inspectors | 0 | 6/10/08 2:42 PM |
| gutter downspout to basement drainage system | David Paterson | Exterior Inspections | 2 | 12/18/06 6:27 PM |
