Old 4/15/07, 8:28 AM
jberthiaume's Avatar
jberthiaume jberthiaume is offline
Default Bedroom Door leading to garage
Can a bedrooom(with proper window size)in a basement be considered legal if there is a door leading to the garage which is properly fire proofed?
Old 4/15/07, 8:41 AM
gbeaumont's Avatar
Default Re: Bedroom Door leading to garage
In one word.............. no
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 4/15/07, 3:23 PM
Keith Swift, PhD. Keith Swift, PhD. is offline
In two words: absolutely not.
InterNACHI Vice President, InterNACHI Editor-in-Chief, co-founder CalNACHI
Old 4/15/07, 4:08 PM
In three words; unsafe to do.
next.
Old 4/15/07, 4:24 PM
Four words, all of which gerry understands: Not on your nelly
Old 4/15/07, 4:31 PM
Old 4/16/07, 5:03 AM
Russel Ray's Avatar
What's a basement?
And why not?
Old 4/16/07, 8:35 AM
dbush's Avatar
dbush dbush is offline
Send a message via MSN to dbush Send a message via Yahoo to dbush
Please Note: dbush is a non-member guest and is in no way affiliated with InterNACHI or its members.
Nope, bedrooms should NOT open into a garage. Has nothing to do with the basement, just the bedroom to the garage.
Old 4/16/07, 8:49 AM
David P. Valley's Avatar
Openings from a private garage directly into a room used for sleeping purposes shall not be permitted.
If you really needed a bedroom in that area, a simple solution would be to build an ante-room (a small entry room) between the new bedroom and the garage. This could be a small closet-sized space, with a fire-rated, self-closing door on the garage side, for firewall compliance. In this way, you could have your attached garage, your added bedroom, and no direct access between the two. Check with your local building department to see if they would accept this approach.
Old 4/16/07, 9:19 AM
Unmoderated Guest
Mr. Valley quotes from R309.1 of the International Residential Code. I'm looking at the 2003 edition, but I can't imagine that this provision would change in any later edition.
This clause further staes that "Other openings betweenthe garage and residence shall be equipped with solid wood doors not less than 1 3/8 inches in thickness, solid or honeycombed steel doors not less than 1 3/8 inches in thickness, or 20-minute fire-rated doors."
Old 4/21/07, 6:17 AM
Frank M. Carrio, CMI's Avatar
Frank M. Carrio, CMI Frank M. Carrio, CMI is offline
ESOP Committee Member
Here's the information from the latest edition. I thought I would throw in a few extras, I hope that some of you find this information to be useful.
2006 International Residential Code for One and Two Family Dwellings
SECTION R309
GARAGES AND CARPORTS
R309.1 Opening protection.
Openings from a private garage directly into a room used for sleeping purposes shall not be permitted.Other openings between the garage and residence shall be equipped with solid wood doors not less than 13/8 inches (35 mm) in thickness, solid or honeycomb core steel doors not less than 13/8 inches (35 mm) thick, or 20-minute fire-rated doors.
R309.1.1 Duct penetration.
Ducts in the garage and ducts penetrating the walls or ceilings separating the dwelling from the garage shall be constructed of a minimum No. 26 gage (0.48 mm) sheet steel or other approved material and shall have no openings into the garage.
R309.1.2 Other penetrations.
Penetrations through the separation required in Section R309.2 shall be protected by filling the opening around the penetrating item with approved material to resist the free passage of flame and products of combustion.
R309.2 Separation required.
The garage shall be separated from the residence and its attic area by not less than ½-inch (12.7 mm) gypsum board applied to the garage side. Garages beneath habitable rooms shall be separated from all habitable rooms above by not less than 5/8-inch (15.9 mm) Type X gypsum board or equivalent. Where the separation is a floor-ceiling assembly, the structure supporting the separation shall also be protected by not less than 1/2-inch (12.7 mm) gypsum board or equivalent. Garages located less than 3 feet (914 mm) from a dwelling unit on the same lot shall be protected with not less than ½-inch (12.7 mm) gypsum board applied to the interior side of exterior walls that are within this area. Openings in these walls shall be regulated by Section R309.1. This provision does not apply to garage walls that are perpendicular to the adjacent dwelling unit wall.
R311.4 Doors.
R311.4.1 Exit door required.
Not less than one exit door conforming to this section shall be provided for each dwelling unit. The required exit door shall provide for direct access from the habitable portions of the dwelling to the exterior without requiring travel through a garage. Access to habitable levels not having an exit in accordance with this section shall be by a ramp in accordance with Section R311.6 or a stairway in accordance with Section R311.5.
R311.4.2 Door type and size.
The required exit door shall be a side-hinged door not less than 3 feet (914 mm) in width and 6 feet 8 inches (2032 mm) in height. Other doors shall not be required to comply with these minimum dimensions.
R309.4 Carports.
Carports shall be open on at least two sides. Carport floor surfaces shall be of approved noncombustible material. Carports not open on at least two sides shall be considered a garage and shall comply with the provisions of this section for garages.
SECTION R310
EMERGENCY ESCAPE AND RESCUE OPENINGS
R310.1 Emergency escape and rescue required.
Basements and every sleeping room shall have at least one operable emergency and rescue opening. Such opening shall open directly into a public street, public alley, yard or court. Where basements contain one or more sleeping rooms, emergency egress and rescue openings shall be required in each sleeping room, but shall not be required in adjoining areas of the basement. Where emergency escape and rescue openings are provided they shall have a sill height of not more than 44 inches (1118 mm) above the floor. Where a door opening having a threshold below the adjacent ground elevation serves as an emergency escape and rescue opening and is provided with a bulkhead enclosure, the bulkhead enclosure shall comply with Section R310.3. The net clear opening dimensions required by this section shall be obtained by the normal operation of the emergency escape and rescue opening from the inside. Emergency escape and rescue openings with a finished sill height below the adjacent ground elevation shall be provided with a window well in accordance with Section R310.2. Emergency escape and rescue openings shall open directly into a public way, or to a yard or court that opens to a public way.
Signed, Frank Carrio, CMI
Certified Master Inspector & Consultant
Certified, WDI Inspector
Founder & Current President, New Hampshire State Chapter NACHI
NACHI, State Representative for Legislative Affairs
Retired: ICC Certified Member
Retired: Code Compliance Inspector.
Retired: ASTM Committee Member
New Hampshire License #0096
Old 6/13/10, 10:51 AM
Peter W. Bennett Peter W. Bennett is offline
Frank, thanks for posting this.
My question is when did this code become effective?
I inspected a 1985 home in a PUD which most of them are this way.
thanks,
pb
Old 6/14/10, 6:14 AM
thanks,
pb
Peter,
Code dates do not matter IMO.
It's simply a safety issue.....
Need a home inspection in Missouri? Check out InterNACHI's listing of Missouri certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 6/14/10, 10:15 AM
Jeffrey R. Pope's Avatar
The requirement dates back to the 50's. Perhaps even earlier.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 6/14/10, 10:23 AM
James H. Bushart's Avatar
thanks,
pb
Should you run into a used house salesman who wants to argue that a violation like this should be ignored since the house was built before the rule was implemented....explain that you would be happy to apply the 1950 standard with the written guarantee from the broker that all vehicles entering the garage will also be pre-1950, that no pesticides, weed killers or other household poisons developed after 1950 will be stored in the garage....as well as pre-1950 manufactured petroleum products, paint products and yard/household tools.
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
Evaporative cooler in garage chellickson Inspecting HVAC Systems 9 7/23/07 12:08 AM
Newbie here with a slab "standards" question Robert Young, #3 Structural Inspections 17 4/10/07 10:48 AM
Garage ceiling & door header Al Barb Interior Inspections 7 3/27/07 12:07 PM
Bedroom Opens to Garage jcooper2 Interior Inspections 10 8/8/06 4:52 AM
