quick question for you all...
Typical 1" blue foam insulation boards 2 ft by 8 ft, polystyrene? used on interior walls... I would not think this is good practice... This was done on a partially finished basement wall... do these not put off toxic fumes if there is a fire? I have yet to get a reply from local code... Let me know your thoughts... thanks Jeff |
Yes toxic gasses released during combustion. I think cyanide gass. It should be covered with drywall or other non combustible cover.
Jeffrey,
Blueboard insulation is relatively hard to ignite, but when it is ignited, it burns readily and emits a dense smoke containing many toxic gases. The combustion characteristics of foam insulation products vary with the combustion temperatures, chemical formulation, and available air. Because of these characteristics, Rigid board (Blueboard) insulation that is used for construction requires a covering as a fire barrier. One half-inch thick (1.27 cm) gypsum wallboard is one of the most common fire barriers. Some building codes, however, do not require an additional fire barrier for certain metal-faced, laminated foam products. Check with your local building code/fire officials and insurers for specific information on what is permitted in your area. |
thanks guys... just as I thought...
Hi. Jeff;
Agreeing with all these statesments in the above post, I would like to add that Kraft Face Insulation and Polyinsynarate insulation would fall in the same category. Just my two cents. Marcel |
How about in an attic? Does exposed foam board insulation need to be covered for a fire barrier?
let's think realisticly. if there is a fire hot enough and intense enough to ignite the insulation, chances are the gasses released are the least of your worries.
John Onofrey Licensed Professional Inspector Houston Home Inspection Houston Home Inspector www.texasinspectors.net John Onofrey President, Grail Media, LLC "Effortless Email Marketing" www.homehintsenews.com 2007 INACHI Inventions and Innovations Award Winner Free! Inspector Email Marketing trial click here |
I would guess that if someone was actually nerved up about flammalbility of a product, he or she could persue the trail of the MSDS of the product and know right off that it has to be protected. SIMPLE
Have a good day. Marcel |
good point Marcel. and i think (not positive) but you should be able to get an MSDS sheet (Material Safty Data Sheet) for any chemical right from the seller. they'll photo copy one they have on file for you. They have to, if you ask.
Hi. Jay and hope your fine.
Yes, anyone and at any one time required, people can request an MSDS sheet on any product on the Market. It is the law. For people that are not familiar with some products on the Market, I think this is crucial to every ones' welfare. Marcel |
i totaly agree. While i was in the military we were required to read every MSDS sheet on EVERY chemical we used, form hydrocloric acid to (yup you guessed it) water. In our fine military system they want you to know all the hazard of good ol' water. it also tells you the boiling point, flame temp, combustion temp, and what it reacts badly with.
Hi. Jay, hope you are fine.
See, you did learn something. Don't you just love those MSDS? Marcel |
| Question about exposed styrofoam insulation. | mlong | Exterior Inspections | 9 | 12/21/07 9:33 AM |
| New Hampshire Real Estate Agents Are Upset! | fcarrio | General Inspection Discussion | 8 | 2/11/06 2:35 PM |
| No Ashi / Nachi Conflict!! | fcarrio | Legislation, Licensing & Legal Issues for Inspectors | 5 | 2/11/06 2:32 PM |
