I did an inspection today for someone getting ready to sell their home in the Spring. The floor in the kitchen near the sliding glass door had an odd appearance that looks like a burn mark. The seller is the original owner and has no idea as to why this appeared. Any ideas? The sliding glass door faces south.
| Need a home inspection in Colorado? Check out InterNACHI's listing of Colorado certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
The sun's UV rays.
That is my first thought, and that the screen is why it is not happening on the other half of the door. I have never seen it like that. Have you seen this before?
Personally I've never seen anything even remotely related here in Death Valley though-- Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
It's a water stain coming from the door under the flooring .
See it around here usually not that pronounced . Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
If there was regular water intrusion causing this stain, you would expect some subfloor softness from rot. |
I would bet it is several things going on condensation and air from the heating outlet
Metal door air leakage , Moisture . Old vinyl floor sunlight. Wayne Wilson East TN Home Inspections LLC Knoxville, Oak Ridge, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-1490 http://site.myhomeinspection.net |
I did see some dark yellow discolouring of this type of flooring around furnace supply air floor registers about 8-9 years ago. The kitchen was directly above the furnace plenums and the 2 ducts serving the kitchen were directly taken off the high sides of the hot air plenum and not a main trunk. The air supplied to these registers was in the 140-150-160*F range while I was there and may have been higher at other times (Colder days with much longer running times). The heated air leaking under register floor flanges had yellowed the flooring all around its edge. |
Ditto. See it often, carpet too.
I don't make too many comments about OLD Flooring myself. |
Photograph 4: Vinyl Flooring
—Pink spots due to moisture problems arising from the impermeability of the vinyl flooring and ventilated and insulated crawlspace underneath.BSI_009
Sorry will not open larger will see how to post it better tomorrow Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. Last edited by rcooke; 12/14/10 at 8:11 AM.. |
4. The pink color comes from digestive enzymes exuded from mold that react with the plasticizers in the vinyl. The mold comes from the substrate being wet because of the impermeability of the vinyl. No vinyl no problem. IMHO, with a continually damp crawlspace underneath, we have a different situation than at a window with apparently heat damaged floor. |
Sorry I disagree I find it in Bath rooms beside the Toilets and Kitchens in front of the sink. From my experience it is caused by water and all that I read says it is from dampness. Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
BTW, are the other HI's who claim they saw discolouration from the sun incorrect? Should they be looking for a moisture source and disregard the obvious? It is obvious that you haven't read enough. In the following article, there is a picture of sun discolouration!! http://www.ntlfloortrends.com/CDA/Ar...100000f932a8c0_ ANd this JUST happens to be from a flooring website with pictures taken by TARKETT employees! Last edited by Brian A. MacNeish; 12/14/10 at 9:11 AM.. |
If the home has air conditioning ,then I expect this could be the cause condensation cold from ac . Ac shuts of cool spot sucks in moist air .
It is hard to do an inspection with out being able to see the home . I have not read where sun can cause this but I do know Foam carpets sure can cause staining . -------------------------------------------------------------------------------------- ("It is obvious that you haven't read enough. ") Thanks for the dig it is obvious to me and many others you are still an ***** Hole . Thanks for confirming this again ... Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. Last edited by rcooke; 12/14/10 at 9:07 AM.. |
