Old 12/9/10, 1:19 AM
smendigian smendigian is offline
Default Can someone provide the right answer?
my prof. just grades the work without letting us know the right answer. Can somebody provide the right answer for me so i know and learn
You are inspecting a ten-year old home.
  1. While inspecting the furnace, you notice the wet area shown in Photo 1.
  2. Tracing the wet area leads you to the exterior wall on Photo 2.
  3. The dark areas seen in Photo 3 are also wet, and a close-up of the patched area can be seen in Photo 4.
  4. You go back outside to view this area, but this section of the foundation wall is facing a neighboring yard, and access is blocked by a tall fence. You knock on the door to find out if you can access this area, but nobody is home. This is an afternoon inspection, and it was raining this morning. What will you report to your client? Include descriptions, observations, implications, limitations, and recommendations.
Photo 1
Photo 2
Photo 3
Photo 4
Need a home inspection in Florida? Check out InterNACHI's listing of Florida certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/9/10, 1:25 AM
Bob Elliott's Avatar
Default Re: Can someone provide the right answer?
Reading your description you have water intrusion through the foundation wall and you should recommend a foundation contractor inspect it .
I also surmise that you should report seeing past repairs and report on the method used for patching in the repair.
Just describe what you see and then recommend action based on your observations.
Your pictures did not load.
Old 12/9/10, 6:43 PM
sorry about that these are the pics thanks
can-someone-provide-right-answer-blph1.jpg   can-someone-provide-right-answer-blph2.jpg   can-someone-provide-right-answer-blph3.jpg   can-someone-provide-right-answer-blph4.jpg
Old 12/9/10, 7:48 PM
David A. Andersen's Avatar
Reading your question (and other threads) I can see that you do not belong anywhere near here...
Enough said...
BPI# 5015804
Old 12/9/10, 9:01 PM
Marcel Gratton's Avatar
Home inspection exams should all be proctored for obvious reasons!
On The Level Inspection
Gatineau, Québec
Old 12/10/10, 12:18 AM
Nick Gromicko's Avatar
Home inspection exams (especially closed-book, proctored ones) teach NOTHING.
Your professor should be providing what he believes to be a proper narrative describing this problem. I suspect your professor doesn't have one.
Fire your professor, for the same reason a client should fire a home inspector for noting a defect without being able to explain why its a defect. Demand a full refund of your tuition.
Find a Home Inspector
Old 12/10/10, 12:26 AM
rsmith24 rsmith24 is offline
Originally Posted by gromicko View Post
Only 2 of the 4 PICs provide enough information. If you are taking a course where you are being graded based on your assessment of PICs like these, you need to find a new school.
I agree one point being it is just as important to know where to find the information. An example would be NO one knows the entire code books by memory.
INSPECTIONLOGOS.COM
"I can keep explaining it for you, but I can't understand it for you".
Nick G.
Monroe Home Inspection
Old 12/10/10, 12:30 AM
Agreed. For example: my ICC exams were all open-book and my ICC course instructors all gave the correct answers to my home work assignments so that I could learn.
Old 12/10/10, 12:37 AM
Dale Duffy's Avatar
Photo 1
Photo 2
Photo 3
Photo 4
You may TRY looking at books or what ever means-sources available to FIND the Answers yourself, having someone tell you the Answer will NOT help you, nor should anyone give him an answer.
You should post a question like this and say "PLEASE don't answer this Question"...!!!
I'm going to find the answer MYSELF and Post it for all to see..!!!
If I'm WRONG, please critique me....!!!
Unbelievable...!!!
Old 12/10/10, 12:43 AM
Helping him with the answer is exactly what his professor should be doing.
Unbelievable...!!!
Fire your professor. Demand a full refund of your tuition.
Old 12/10/10, 12:49 AM
Christopher Currins's Avatar
This guy, Sarkis, is not for real, can't you see it.
Christopher Currins
Certified, Licensed
Old 12/10/10, 12:53 AM
It is Ben .G..
I can tell from the low amount of photo use education.(hahaha!)
Old 12/10/10, 3:59 AM
i dont know if i have to post this in all the threads but im going to anyways. I apologize for causing such a commotion over a couple of Questions i wanted to know the correct answer for. As you can tell exams are coming up and i want to study for obvious reasons. I will vaguely describe my scenario as i do not want to cause any more commotion. I study at a college in Ontario and my proffs run in class and online courses and mostly everything is through the computer and its quite an annoying and lengthy process,so i thought i would just post them. These are a couple of cases we had to complete earlier in the semester they are not tests or exams as you can see the detailed Questions and pics. I thank Those that took their time and read my posts and i also thank those that actually tried to help me out with my studies. A special thanks goes out to those who decided to try and humiliate me cause they are so cool that they know the answer and they dont want to tell me .WOW i m heartbroken...LOL. Relax dont get all worked up i only asked couple of questions not anything else..... (insulting, personal,rude...) BTW i didnt join NACHI because i wanted business i joined so i could further my education and be a better and sure of alot nicer inspector than you(s). There is too much drama and alot of unlayed ppl in here so to clear the air this will be my last post.
Good Luck and Good Health to all my new fellow members. Nick thanks for the support.
p.s. sorry i cant do anything about the getting layed part lol.
oh yeah i forgot it says 24 hr online support from engineers
Old 12/10/10, 5:30 AM
Banned
Say that enough times and some may believe you.
From what I remember of my earlier days, an Exam was never a teaching tool but was to test your knowledge retention of what had been taught or self-taught.
An exam will, at best, teach you what you didn't know.
Do you believe we should have unproctored, online exams for our mechanics, doctors, dentists, lawyers , etc.......and then list them as "Featured" in their chosen online profession? No.....you don't have to answer that as I believe we already know your answer or spin!
Old 12/10/10, 11:40 AM
Sarkis, it appears you have 2 hurdles:
The first is that you have a professor who gives you hypothetical questions and then won't answer them himself.
I'd fire this professor.
We have the same issue with a school in New York (where our members must attend to get their CE as NY still doesn't accept online CE). The professor just fails everyone who submits certain homework assignments, but won't explain why.
Your second problem appears (to me at least) that English might not be your first language. I don't own this product (or I'd send it to you for free), but I recommend it in your case: http://www.inspectoroutlet.com/inspe...arratives.aspx
First 2 to answer correctly win InterNACHI sunglasses. gromicko Exterior Inspections 13 12/28/09 7:44 AM
