Old 6/3/08, 5:14 PM
aglad aglad is offline
Default Ceiling insulation Question
This is a flat roof with no attic and no venting. The only space between the roof deck and the ceiling is the width of the rafters. What is the proper way of insulating this ceiling.
ceiling-insulation-question-taylor-tear-out-kitchen-040.jpg   ceiling-insulation-question-taylor-tear-out-kitchen-042.jpg
Old 6/3/08, 7:49 PM
Troy Farmer's Avatar
Troy Farmer Troy Farmer is offline
Default Re: Ceiling insulation Question
Fibergalss Batts (rolled batts)
Troy Farmer
Presidential Inspections LLC
Chapter President Southern Idaho
PO Box 2144
Eagle, Idaho 83616
208-573-5300
http://www.presidentialinspection.com
http://info@presidentialinspection.com
"He who can, does. He who can’t, teaches"
"Where would we be without Teachers"
Old 6/3/08, 8:06 PM
mreusch mreusch is offline
Send a message via Yahoo to mreusch
You could have it spray foamed possibly.
Old 6/3/08, 8:38 PM
Brian E. Kelly's Avatar
Either batts or spray. If fiberglass batts are used no vapor barrier, as the paper vapor barrier is not supposed to be left exposed in the attic.
Old 6/3/08, 9:17 PM
jkogel jkogel is offline
Anthony, you should ask some local builders, as to the question of vapour barrier and venting. I believe outdoor humidity is higher in Florida and there are unique rules there. In my cold wet climate, a tightly sealed vapour barrier on the warm interior cieling is a must. Wouldn't build anythng with a flat roof, either.
John Kogel
www.allsafehome.ca
Old 6/3/08, 9:29 PM
Is the flat roof foam on top?
No vapor barrier was not the right answer.
This vapor retarder is flammable
and should not be left exposed.”
This warning is also printed on
most packaging and product literature.
For those applications where the
vapor retarder facing is left exposed,
such as garage walls or ceilings of
warehouses and other storage areas,
flame spread-resistant (FS-25) faced
fiber glass insulation is available.
http://www.naima.org/pages/resources/library/pdf/BI472.PDF
Old 6/4/08, 2:55 PM
klott's Avatar
klott klott is offline
Hard to tell, but those look like 2"x6" over a pretty long span also, especially on a flat roof.
Question about exposed styrofoam insulation. mlong Exterior Inspections 9 12/21/07 9:33 AM
Insulation question mkiss1 General Inspection Discussion 6 5/28/07 8:12 PM
Consumer needs help with missing insulation. gromicko Interior Inspections 4 2/25/07 7:13 PM
Ceiling Fans Question jsieg Electrical Inspections 12 1/10/06 2:31 AM
