Pictures may be difficult to see but what is a proper way to suspend a Chandelier of this size. Estimating it to be 5' Diameter x 7' Tall and only can guess a couple hundred pounds in weight. Picture taken up in attic show chain wrapped around a steel cross bar and structured web member.
John Scaparo Innovative Home Inspection, LLC Canton, Michigan 48187 734.664.5853 john@InnovativeHomeInspection.com Michigan Licensed Residential Builder 2101201845 InterNACHI MI #09041012, AHIT Member Plymouth Michigan Home Inspector
Canton Michigan Home Inspector "Helping To Secure Your Home Investment" Looking for link exchange partners. If interested send me your link. |
| Need a home inspection in Michigan? Check out InterNACHI's listing of Michigan certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
It really depends on the size and span of the unistrut, but based on the fact that someone felt a chain was in order, I'd have no problem deferring this to a qualified contractor.
I agree if you have to ask then you are nervious ( a good thing ) . Pass it on Immediatly . Remember write hard talk soft and miss nothing . Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
This is a new home construction. At first all I saw was just the chain from the distance then when I got closer and pushed away the insulation I saw the unistrut and it was not secured. Actually I could not get a clear view because of the insulation obstructing most of the installation. I never came across this before so I did report this to the home buyer and did make recommendation they talk to the builder to qualify the installation. All I could think of if this thing let loose its not going to good because this was at least a 20' ceiling.
Sure don't look professional ! Yes I'd get the contractor to look at this !
galaxyhomeinspections.com An amateur built the Ark ! Professionals built the Titanic ! |
| Batt insulation over suspended ceiling | smcarthur | Interior Inspections | 7 | 3/11/11 9:58 AM |
| First 2 to answer correctly win InterNACHI sunglasses. | gromicko | Exterior Inspections | 13 | 12/28/09 7:44 AM |
| Engineer Botches Home Inspection...Suspended by Regulating Agency | jbushart | Miscellaneous Discussion for Inspectors | 0 | 1/25/08 5:58 PM |
| Suspended Concrete Floor | cbrands | Structural Inspections | 21 | 1/20/08 9:21 PM |
