Home built in 1850 the basement had a brick floor also
Ron Bero Green Bay Wisconsin All Star Inspections www.greenbayhomeinspector.com Serving Northeastern Wisconsin Including Brown,Door,Kewaunee,Manitowoc,Calumet,Outagame, Shawano,Oconto,and Marinette Countys.
| Need a home inspection in Oregon? Check out InterNACHI's listing of Oregon certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
The chimney in my mothers house is like that.
These were built this way on purpose, usually a case of the center of the room where the fireplace or wood burning stove sits is not the center of the roof ridge. The mason would start to offset the bricks to line the two up. Performing Home Inspections in Council Bluffs, Missouri Valley, Glenwood, and surrounding areas Active Rain Member Last edited by jharrison; 3/27/10 at 6:36 PM.. |
That is correct--quite common around here.
You see that inside attics quite a bit as well.
It's called a brick corbel.
Rick Sovastion Advanced Home Inspections 1711 Grafton Road Morgantown, WV. 26508 304-291-8282 Go WVU Mountaineers |
mnicholet is a non-member guest and is in no way affiliated with InterNACHI or its members.
There are corbelling rules including :
a brick shouldnt be corbelled more than 1 inch from the brick below and the total corbelling shouldnt be more than 1/3 of the wall thickness. Those bricks in the pic look to be corbelled more than 1/3 of the wall thickness. http://books.google.ca/books?id=OMVc...page&q&f=false |
| What's Inside A Chimney | mcyr | Inspecting HVAC Systems | 14 | 9/17/08 6:11 PM |
| Chemical Chimney cleaners do not work | rcooke | Canadian Inspectors | 6 | 2/12/08 12:02 AM |
| Difficult Chimneys | thance | Inspecting HVAC Systems | 2 | 1/29/08 8:16 PM |
| Floating Chimney Syndrome | mcyr | General Inspection Discussion | 8 | 7/24/07 11:49 PM |
| Fireplace Enclosure | jpope | Interior Inspections | 19 | 10/25/06 5:08 PM |
