Old 9/16/06, 4:06 PM
jlybolt jlybolt is offline
Please Note: jlybolt is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Chimney Flue
I run into many chimney flue like this one. I always recommend the insulation be pulled back away from all flues and to Seal the gap between the flue and metal flashing with special high-temperture silcone caulk. I would like to hear others points of views on this. Thanks
Old 9/16/06, 4:13 PM
Joseph Hagarty,  CMI's Avatar
Default Re: Chimney Flue
Recommend a Level 2 Inspection of all Chimneys and Flues be conducted prior to closing.
http://www.csia.org/pressroom/press-...-explained.htm
Joseph P. Hagarty
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 9/16/06, 4:58 PM
Shawn Rowe's Avatar
Shawn Rowe Shawn Rowe is offline
James, In this case I would probably just move whatever insulation was there (if accessible). It would actually take less time to move it than to write it up and of course, recommend the Level 2.
Many manufacturers don't specify fire caulking around factory firestops from what I have found. Maybe someone else can expand on this.
Old 9/25/06, 11:29 AM
Patrick Bolliger's Avatar
Many manufacturers don't specify fire caulking around factory firestops from what I have found. Maybe someone else can expand on this.[/quote]
It could be due to expansion and contraction of the metals. (guessing)
I would check with the MFG on the proper installation of this flue fire stop.
In general:
I believe any recommendation we make should be carefully checked before we tell the client. The potential for mis-information is huge and could make us look bad and should the client DIY. What happens when it's wrong?
Does the warranty or service plan get void... "Dam Home inspector told me to do it"....
Be careful..
Old 9/25/06, 11:02 PM
good advise Patrick, Thank you everyone for your replies
Old 9/26/06, 7:38 PM
Check out the proper attic section required.
http://servicesales.com/metal-fab/shields.html
Hope this helps.
Marcel
Old 9/26/06, 8:06 PM
hspinnler's Avatar
hspinnler hspinnler is offline
Please Note: hspinnler is a non-member guest and is in no way affiliated with InterNACHI or its members.
But what if the chase is open to the lower level? You have a whole chase full of blown insulation in there because there is no firestop between ceiling and attic. Get the large wet-dry vacuum out I guess.
Old 9/29/06, 5:01 PM
Mario A. Kyriacou, CHI's Avatar
Mario A. Kyriacou, CHI Mario A. Kyriacou, CHI is offline
ESOP Committee Member
Shawn
Take the time to write this one up.This is definetly a defect and you can't solve it by moving the insulation away.
I would suggest an 'INSULATED ATTIC RADIATION SHIELD' remember that you have to maintain 2" safety clearance from surrounding combustible material.
Mario
'Imagination is more important than knowledge' (sometimes)
Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007
www.360degreeshomeinspections.com
Tel.# 416-722-6132
e-mail torontohomeinspector@yahoo.com
WOOD cap over Chimney Flue!?! mlong Exterior Inspections 4 9/11/07 10:33 AM
Gas and oil hot water tank and Boiler Share Vents hvanderbeek Miscellaneous Discussion for Inspectors 8 1/25/07 5:22 PM
Flue Size when size matters? msylvester Inspecting HVAC Systems 14 1/20/07 11:29 PM
Fireplace Enclosure jpope Interior Inspections 19 10/25/06 5:08 PM
