It is official, Chinese Drywall has been found in St. Augustine.
We verified that a 2006 St. Augustine home was indeed built with Chinese Drywall. The home was built by a small builder in town and not one of the larger track home builders mentioned in the Class Action Suit. According to the homeowner, the construction supply lists indicate that half the home was built using two different wallboards. Both types of wallboard were provided by a very well known construction material supplier. The homeowners describe typical “Chinese Drywall” symptoms over the last couple of years. Air handler coils have been replaced twice. Multiple plumbing fixtures have tarnished and/or corroded. The sulfur smell is not bad all the time but some days are worse than others perhaps relating to the humidity level. Take note: *this is not just occurring with large builders. *this is not a South Florida problem *homes may contain just part Chinese Drywall. *A sulfur smell is NOT always detectable. *This home is not in a newer subdivision. ************************************** Shawn Rowe, CMI HomeFirst Inspection Services, LLC - InfraRed Specialist (Level 1 & Building Science certified) - Code Certified Residential Building Inspector - Certified Master Inspector -- Serving NE Florida, St. Johns, Duval, Flagler, Putnam counties -- |
| Find an InterNACHI certified New Mexico Home Inspector (and anywhere else in North America) |
Shawn,
Thanks for the info! Hope all is well with you. Are you coming to the spring cont. ed conf. next month? |
Your confirmed the symptons. How did you actually confirm that it was Chinese drywall??
Drywall was removed.
Do you have a picture for all to see the markings on the back of the drywall. I am asking this so everyone can see how the drywall is marked. There are two kinds of drywall that come from China. Some is OK and some is not. Thanks.
When and where is the spring conf
Another recent inspection confirmed a home with KNAUF China ASTM C-36 drywall but with absolutely no signs or symptoms of corrosion or odors. Here are two photos from my inspections of Knauf Drywall. One is from Tianjin (known to be bad) the other from Donssuan (supposedly NOT bad). Check out the DOH site as they have recently added a map of known cases. http://www.doh.state.fl.us/environme...Statslarge.gif ************************************** Shawn Rowe, CMI HomeFirst Inspection Services, LLC - InfraRed Specialist (Level 1 & Building Science certified) - Code Certified Residential Building Inspector - Certified Master Inspector -- Serving NE Florida, St. Johns, Duval, Flagler, Putnam counties -- |
I cannot tell from the first picture (cant read the name of the town it was manufactured in), but the second picture is stamped with ASTM and is not one of the ones importe from China that is causing the problem.
Hi to all,
for those that are interested, I will be running a class covering Chinese Drywall at the next West central Florida chapter meeting held at the CATcleaning facility on june 13th 2009. Click here for details http://www.nachi.org/forum/f13/west-...meeting-39701/ Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
I hope I didn't confuse anyone with last post. I basically wanted to show the difference between the two different types of KNAUF drywall that I have observed here. Not all KNAUF drywall is bad.
William, you cannot go by "ASTM". Both Chinese drywall samples I have are marked with ASTM C36. You have to pay attention to the print type and size and be able to read more than KNAUF. ************************************** Shawn Rowe, CMI HomeFirst Inspection Services, LLC - InfraRed Specialist (Level 1 & Building Science certified) - Code Certified Residential Building Inspector - Certified Master Inspector -- Serving NE Florida, St. Johns, Duval, Flagler, Putnam counties -- |
Actually, you'd need to see the BACK of the drywall, which in most cases is impossible for an inspector to do unless he/she is present at the time of installation.
In the attic you can see the back of the drywall.
| Home Inspector Listings | jbowman | Miscellaneous Discussion for Inspectors | 225 | 10/18/11 7:54 PM |
| Toxic Drywall from China | inxil | InterNACHI & RealMatcher Blogs | 13 | 3/13/09 12:14 PM |
| Bungalows to Mansions Professional Home Inspection, LLC | bgraham | Miscellaneous Discussion for Inspectors | 7 | 1/11/09 4:03 PM |
| Gainesville,fl Alachua county Home Inspection | bgraham | Miscellaneous Discussion for Inspectors | 0 | 9/1/06 12:22 PM |
