This is the first time I have seen this.
Do you see what I see?
| Need a home inspection in Iowa? Check out InterNACHI's listing of Iowa certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
So you can operate the switch without removing you hand. It must be a safety feature
Handrail brackets upside down or the blocked switch?
Very good Bob. I kept banging my knuckles. It was the same on all three stairways.
At least Mr. Handy was consistent. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
Further proof we need more than canned lingo in reports. |
How wide is that stairs. The door at the top looks to be about 2 feet wide.
THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
The door is fine. It's partially closed.
The attic access wasn't so fine. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
My answer is to unscrew and enter in the above situation. Yes if it had items ,that would be different. |
I did have to remove the top closet shelf. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
Should be code that attic hatches (scuttles) must be in walk-in closets, halls, etc; not in 2' wide closets with shelving!!!
It is now but it was not when this house was built.
You're lucky to have that in your area!
| Home Inspector Listings | jbowman | Miscellaneous Discussion for Inspectors | 230 | 3/21/12 9:35 PM |
| Furnace flue how close to wood | abishop | Inspecting HVAC Systems | 13 | 5/30/06 2:15 AM |
