Does this count as only three risers or do you count the others past the triangular landing?
In other words, does code require no handrail here, a short handrail or a continuos handrail? B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
| Find an InterNACHI certified Alaska Home Inspector (and anywhere else in North America) |
Code does....and if it didn't, common sense would, IMO.
James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 Inspecting in Aurora, Branson, Carthage, Granby, Joplin, Kimberling City, Monett, Mount Vernon, Neosho, Nixa, Purdy, Reed Spring, Republic, Springfield and surrounding areas. |
James could be a bit more clear.
Code requires the hand rail to begin at the edge of the first step. He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father |
tbloore is a non-member guest and is in no way affiliated with InterNACHI or its members.
I would agree.
If you start off tumbling with the first steps...what good is a handrail that you can't reach. |
I believe the requirement is for 4 or more risers (2006 IRC) pg. 8. Here is a link to the document. Downloadable for future reference.
http://www.stairways.org/pdf/2006%20...C%20SCREEN.pdf "War is an ugly thing, but not the ugliest of things; the decayed and degraded state of moral and patriotic feeling which thinks nothing is worth a war, is worse. A man who has nothing which he cares more about than he does about his personal safety is a miserable creature who has no chance at being free, unless made and kept so by the exertions of better men than himself." - John Stuart Mill |
IRC (2006) 311.5.6 Calls for a continuous handrail for "each continuous run" of treads....but code or no code, it's the right thing to do.
James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 Inspecting in Aurora, Branson, Carthage, Granby, Joplin, Kimberling City, Monett, Mount Vernon, Neosho, Nixa, Purdy, Reed Spring, Republic, Springfield and surrounding areas. Last edited by jbushart; 12/31/09 at 5:22 PM.. |
That does not appear to be deep enough to even be a landing, aren't they all steps?
You can't just make up what you want to whether it is right or wrong, particularly when you base your assumptions on written codes. The only ones who can add to or take away are the AHJ. However, you CAN recommend anything when you deem something to be unsafe or when it is a gray area.
R311.5.6 Handrails. Handrails shall be provided on at least one side of each continuous run of treads or flight with four or more risers. "War is an ugly thing, but not the ugliest of things; the decayed and degraded state of moral and patriotic feeling which thinks nothing is worth a war, is worse. A man who has nothing which he cares more about than he does about his personal safety is a miserable creature who has no chance at being free, unless made and kept so by the exertions of better men than himself." - John Stuart Mill Last edited by dedwards; 12/31/09 at 5:29 PM.. |
It is a continuous run and needs a continuous railing, IMO...
Scroll half way down and see info about winders....
http://www.inspectapedia.com/interiors/Stair_Codes.htm B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
That does not qualify as a landing. It needs a handrail.
Uniform width of stairs andA flight of stairs shall not have a vertical rise greater than 12 feet (3658 mm) between floor levels or landings. The width of each landing shall not be less than the stairway served. Every landing shall have a minimum dimension of 36 inches (914 mm) measured in the direction of travel. http://www.stairways.org/pdf/2006%20...C%20SCREEN.pdf Christopher Currins Certified, Licensed Proudly serving the Illinois Metro-East Illinois Home Inspector Top 5 Tasks for January |
I would count a short separate section as being in spirit of code.
My thought also... I don't see a landing.
Those are winders and the hand rail should start at the top step
| Garage/house fire door | Steven C. Meyer | General Inspection Discussion | 15 | 2/5/08 8:06 AM |
| No "H" clips? | jbreazeale | Structural Inspections | 7 | 5/17/07 3:28 PM |
