The common mold that gets on the back of the drywall under the sink
from water splashing and coming thru the sprayhead. etc... A licensed plumber comes in and fixes the sink so it no longer leaks under the sink.....I come in and see the dead mold on the drywall. What is the solution? Can it be treated then painted over? Or does the drywall have to be replaced. What is a good write up? David An Ounce of prevention is better than a pound of cure :} |
| Need a home inspection in Arkansas? Check out InterNACHI's listing of Arkansas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Clean as needed. Paint with Kilz.
Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
Mold or Mildew?
What Steve said, unless there is enough Mold left to make me a good sandwich with...if so, give me a call, I haven't had a good ole Mold sandwich since I visited Toxic-James in Missouri---
If surface mildew, clean, Kilz-it, call it a day...but tell the client to do what they think is best, so nobody is waking up in the morning to a Process Server-- Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
David Garton Eagle Eye Inspection Services david@yubacityhomeinspection.com http://yubacityhomeinspection.com Licensed Building Contractor Serving Yuba City, CA. and the surrounding areas (530) 415-1269 |
Organic growth
Performing Home Inspections in Council Bluffs, Missouri Valley, Glenwood, and surrounding areas Active Rain Member |
Visible organic growth consistent with mold was observed in (( )) and other areas. The underlying cause is moisture. No visible water intrusion at time of inspection. Determining whether the material observed poses a health risk is outside the scope of this inspection. Recommend eliminating conductive conditions (source of excessive moisture) to prevent further growth and test further if deemed necessary. An Indoor Environmental Professional should be consulted for evaluation and to determine correct course of action if desired. Be aware that improper removal procedures can actually be detrimental to the indoor air quality.
Basic mold cleanup steps and more related information from the E.P.A. This is probably more than you need in your case, but better safe than sorry. Christopher Currins Certified, Licensed Proudly serving the St.Louis Metro St. Charles, St. Peters, Maryland Heights, O'Fallon, Florrisant, MO Home Inspector BLESSED ARE THE CRACKED, FOR THEY ARE THE ONES WHO LET IN THE "LIGHT"!
Remove the food source. The paper is the food, remove it and spray with KILZ.
If there are spots in the core of the drywall remove it completely. THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
The IICRC S520 needs to be followed. A lot of times there is a considerable amount of mold behind the base cabinet. Air testing will be needed to be done to determine how much area needs to be cleaned.
In otherwords, refer it to a professional just as Chris says. Braun Inspection Consultants Serving Jefferson City, Columbia, Sedalia, Fulton and Lake of the Ozarks
Scenerio #1 ... "Impressing the used house salesman for future referrals" ... play it down.
Scenerio #2 ... "Helping the economy by encouraging unnecessary spending on elaborate tests" ... play it up. Scenerio #3 ... "Providing a complete, accurate and unbiased inspection report" ... report the finding as you observed it and let the buyer decide what action to take. Remember, the identification of "mold" and its presence is outside the scope of a home inspection. James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 |
I love that link for basic mold cleanup. David An Ounce of prevention is better than a pound of cure :} |
Thanks everybody for the feedback. Im going to save the thread and use the
info. as I need it. An Ounce of prevention is better than a pound of cure :} |
Mr. Bushart,
Your scenerio's 1 & 3 are good, but #2, I feel you are mistaken. Scenerio #2 ... "Helping the economy by encouraging unnecessary spending on elaborate tests" ... play it up. Its only unnecessary if the clients health is not a concern. Steven Wessler SpyGlass Inspection Services, LLC Serving The Lake of the Ozarks, Missouri INACHI: 09021806 www.spyglassinspect.com |
| Fighting Mold — The Homeowners' Guide from CMHC | mkyriacou | IAC2 Indoor Air Forum | 1 | 9/17/09 2:32 PM |
