Old 6/23/09, 3:09 PM
David Nasser's Avatar
David Nasser David Nasser is offline
Default Common wall of garage is Laundry room / firewall ?
the backwall wall is common to the laundry room.....the door opens
to a bonus room......the house was built in 1964....the common wall is wood ....Should I recommed that drywall be installed? ( as a fire barrier)
all of the wall ......left of the door is a laundry room. Directly thru the
door is a bonus room (living area)
Find an InterNACHI certified Minnesota Home Inspector (and anywhere else in North America)
Old 6/23/09, 7:19 PM
Chuck Evans's Avatar
Default Re: Common wall of garage is Laundry room / firewall ?
Depends how thick the plywood is. The door is not fire rated.
Chuck Evans (TREC #7657)
Houston Home Inspector
Houston, TX
Old 6/24/09, 11:02 PM
Jeffrey R. Pope's Avatar
The wall and door must be a rated assembly.
This is what I would state;
There is no firewall separation between the garage and the residence, which is mandated. You should consult and employ the services of a qualified contractor to install the components necessary to maintain a separation that will comply with State or Local requirements.
For the door, I would state;
The house entry door is not identified as being fire-rated and must be, to maintain the necessary firewall separation between a garage and living quarters, and will need to be replaced.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 6/24/09, 11:10 PM
Joe Funderburk, CMI's Avatar
Jeff, do you feel there is a duty to upgrade an older home to today's standards? I cringe at the word "mandated" and "will need to be replaced". This is still America and buyers nor sellers don't have to do as we say. I would phrase it a little less authoritatively, such as:
"There is no firewall separation between the garage and the residence, which is required by today's commonly accepted construction standards...We recommend installation of a functional fire barrier for safety reasons." (Emphasis added.)
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 6/24/09, 11:36 PM
No, but to the best of my knowledge, there has always been a fire separation requirement for an attached garage.
If I considered it an "upgrade" to newer standards, I would word it that way.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 6/24/09, 11:59 PM
gbeaumont's Avatar
Agreed, that requirement goes back to the 1920's if memory serves
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 6/25/09, 12:02 AM
Well if so, it must not have been enforced here in the Carolinas. I grew up in a home built in 1972 with a plywood separation (Mother still lives there). Most homes around here older than 20 years old do not have a functional fire barrier.
Theodore Roosevelt
Joe Funderburk, CMI
Old 6/25/09, 12:28 AM
gbeaumont's Avatar
Hi Joe,
that may well be the case in your area, but that would surprise me.
The 1 hours firewall rule was in the 1st edition of the UBC in 1927 (yeah I just had to look it up) and UBC and others are the for-runners of todays IRC/IBC.
Regards
Gerry
(Mark B Adams)
NACHI02121106
Old 6/25/09, 6:47 AM
David P. Valley's Avatar
There's absolutely no requirement to upgrade an older home to today's code standards, but I would always recommend a firewall upgrade (separating living area from garage area) in older homes simply as a safety feature.
Old 6/25/09, 7:54 AM
Exactly...I recommend the same.
Larry Kage, CMI
231 929 3525
Old 6/25/09, 10:51 AM
I don't consider it an "upgrade" when it is/was a required component.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 6/26/09, 3:32 AM
Mark Thorman Mark Thorman is offline
Unmoderated Guest
Please Note: Mark Thorman is a non-member guest and is in no way affiliated with InterNACHI or its members.
It could be that the laundry to bonus room is the intended firewall. Was there a fire rated door possibly at that location?
www.MauiHomeInspections.com
Old 6/26/09, 8:22 AM
Mario A. Kyriacou, CHI's Avatar
Mario A. Kyriacou, CHI Mario A. Kyriacou, CHI is offline
ESOP Committee Member
David,
Was this garage created from an existing car port?
'Imagination is more important than knowledge' (sometimes)
Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007
www.360degreeshomeinspections.com
Tel.# 416-722-6132
e-mail torontohomeinspector@yahoo.com
Old 6/26/09, 11:40 PM
With this sort of thing, I mention that it may not have been required at the time the home was built, but that widely-accepted modern standards require it for safety reasons, then I recommend it be brought into compliance with modern standards.
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 6/26/09, 11:57 PM
Unmoderated Guest
Originally Posted by mkyriacou View Post
David,
This idea gets my vote which makes it an incomplete carport to garage conversion and repairs should be peformed to bring it into the accepted standard that has been in force since the first building code in 1927.
something else to chew on john bubber Structural Inspections 706 4/25/12 7:13 AM
Where do I put the Aquarium? mcyr Structural Inspections 3 11/6/07 3:05 PM
Fire wall tyeager Structural Inspections 38 8/24/07 11:17 AM
