Old 11/28/12, 7:23 PM
Mark Ellison, CMI's Avatar
Mark Ellison, CMI Mark Ellison, CMI is offline
Default Compressed Insulation R values
Does anyone have information/data for quantifying compressed insulation R values?
Cheers
Mark
Need a home inspection in Delaware? Check out InterNACHI's listing of Delaware certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/28/12, 7:34 PM
Barry Adair's Avatar
Location: this side of the dirt, another successful day
Default Re: Compressed Insulation R values
Inspect-R® Density Gauge
badair
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
National Association of Commercial Building Inspectors & Thermographers™ Member ID 12011-14TX
life is the random lottery of events followed by numerous narrow escapes, accept the good
Old 11/28/12, 7:35 PM
Marcel R. Cyr, CMI's Avatar
Marcel R. Cyr, CMI Marcel R. Cyr, CMI is offline
Not sure if this is what you are looking for.
Insulation compression Chart
Cyr Home & Commercial Property Inspections
Inachi Award Winner 2009
Old 11/28/12, 9:44 PM
Thanks Gents. I wasn't clear... If you have say 12" of blown fibreglass you'd have R40 approx. After sparky goes into the attic and sits on the insulation while he installs can lights and leaves it at 3" what's the R Value? This was a point of contention with the selling agent this afternoon. We all know it loses R as it's compressed, but I have no chart/gauge/notes on this subject. I was hoping there might be an article or something on this.
Thanks,
Mark
Old 11/28/12, 10:29 PM
James E. Braun, CMI's Avatar
No, 12" of blown fiberglass in an attic is about an R-25 http://www.allwallsystem.com/design/RValueTable.html.
I do not know the R-value when it is compressed.
Braun Inspection Consultants
Serving Jefferson City, Columbia, Sedalia, Fulton and Lake of the Ozarks
Old 11/28/12, 11:20 PM
Sorry, yes. This was rock wool.
We would all agree that settled or "squeezed" in this case would reduce the R value though, yes?
Old 11/28/12, 11:57 PM
Robert Ernst Robert Ernst is offline
When you compress insulation the r-value per inch can go up but the rated r-value goes down. So if it's compressed down to 3.5" then typically it is rated at the standard r-value at 3.5". But since the whole attic is usually not compressed in every area you have to use a weighted area value calculation to get the best idea of it's effective r-value.
Nevada Inspector of Structures #1730
Nevada Energy Auditor #30
www.homecsi.com
Old 11/29/12, 4:40 PM
David A. Andersen's Avatar
BS, No it is not!
The rated value is based on the manufactured consistency of the insulation.
3" of R-11 is not the same as 3" of R-19...
Review "conduction".
"working together to get-IR-done" Chris Walsh
Bracebridge, Ontario:
BPI# 5015804
Old 11/29/12, 7:15 PM
David is correct.
“All insulation materials… shall be installed in accordance with manufacturer’s instructions” is found in every published edition of the Model Energy Code (MEC) and the International Energy Conservation Code (IECC).
A read of this Article here, may help.
Insulation Inspections for Home Energy Ratings
R-Values Per Inch of Some Typical Insulating MaterialsMineral Wool Batts3.5Fiberglass Batts3.1 - 3.5Rock Wool (Loose Fill)3.0 - 3.3Cellulose (Loose Fill)3.2 - 3.8Fiberglass (Loose)2.2 - 2.7Perlite (Loose)2.3 - 2.7Polystyrene Boards (Rigid)3.6 - 5.3Polyurethane Boards (Rigid)5.6 - 7.7
Old 11/29/12, 8:37 PM
Thanks guys. I just thought there may have been a study done on what "X" inches of "type" insulation is rated at when it's compressed to "Y".
I had a selling agent challenge my suggestion of topping up compressed areas. As I had no academic literature I though I'd see what I could learn on the subject.
Cheers
Mark
Old 11/29/12, 8:41 PM
BPI states R-values of installed insulation shall be determined based on an actual
measurement of the insulation depth and the R-value per inch for that product.
In this case if there is loose fill unknown manufacture. Default Values for Insulation
When manufacturer’s rated R-values for insulation are not available, use the chart below
to estimate the R-value per inch for the installed product.
The chart has no value for compression. It only addresses fluffing. The fact is the compression changes the r-per inch only slightly.
www.homecsi.com
Old 11/29/12, 10:22 PM
ROBERT YOUNG, CMI ROBERT YOUNG, CMI is offline
Send a message via Yahoo to ryoung7
Originally Posted by badair View Post
Thanks Mr. Adair.
Bloody nice link.
I have been using that wrench-less chuck for 15 years but you must keep it clean. Mine were for my concrete blades on 4, 4.5, 7 grinders. Sears craftsman had them many moons ago.
Robert Young's Montreal Home Inspection Services Inc.
3510 rUE bENNY SUITE # 401
Montreal Quebec H4B 2R8
http://montreal-home-inspection-services.com
Old 11/29/12, 10:41 PM
Randy Mayo, P.E.'s Avatar
Randy Mayo, P.E. Randy Mayo, P.E. is offline
I developed the first table which is the estimated R-Values of blown cellulose that has been compressed. The following assumptions have been made:
  • The manufacturers of cellulose list the R-Value of their product "after settlement" which is about 10 to 20 percent.
  • The density after settlement is approximately 3.62 lbs/ft3
  • The ASHRAE handbook was used to determine the change in the Thermal Conductivity versus the change in Density. Basically as the cellulose compresses the density goes up. As the density goes up the thermal conductivity goes up. The R-Value is the reciprocal of thermal conductivity or (1 divided by the thermal conductivity), which means the R-value goes down.
  • The compressed R-Values were rounded to the nearest 0.5 so that's why you see several numbers the same. For example R-22, R-24, & R-26 all show R-18 when compressed into a 2x6. However the true R-Values were 18.2, 18.0, & 17.8
You could use this as a guide for sections of an attic where foot traffic has compressed the insulation or plywood was placed over the insulation for storage.
The second chart is for compressed fiberglass batts produced by Owens Corning.
These charts are very generic so don't stick you neck out too far when using them...
compressed-insulation-r-values-compressed-cellulose.jpg   compressed-insulation-r-values-compressed-fiberglass.jpg
Randy Mayo, P.E.
573-201-8162
www.rlmengineers.com
Old 11/29/12, 11:06 PM
Its a good night to visit the MB. Thanks Mr. mayo.
Very nice work on your behalf.
Old 11/30/12, 8:23 PM
An HI An HI is offline
Please Note: An HI is a non-member guest and is in no way affiliated with InterNACHI or its members.
Cellulose has a very nice property......it maintains its R value over a range of densities from about 2.2 lbs/cu ft to 4.0 lbs/cu ft. In that range, the old style material R value was 3.6/inch.
The newer material manufactured by the "Fiberizer" process has an R value of 3.8/inch with a density of only 1.8 lbs/cu ft......nice- higher R using less material!!
From: http://www.insulationusa.com/cellulose_vs_fiberglass/
Cellulose
The R-factor of cellulose insulation is approximately 3.8 per inch and it does not vary significantly over a wide range of densities. In an attic, 10 inches of cellulose insulation will have an R-Value of about R-38, regardless of the density of the material
Insulating Your House from CMHC mkyriacou Canadian Inspectors 10 2/14/10 3:50 PM
Poly being applied to Basement walls dvalley Interior Inspections 40 11/24/09 10:49 PM
Thermal insulation research for sustainable construction mkyriacou Green Building Inspections 0 3/2/09 11:04 PM
Options in selecting materials for basement construction wdevries Canadian Inspectors 2 8/4/08 1:30 PM
New Old Insulation rcooke Canadian Inspectors 1 12/13/06 5:25 PM
