Charles Jones is a non-member guest and is in no way affiliated with InterNACHI or its members.
I want to calculate the indoor basement cumbustion free area. the total basement is 800 sq. computer room ,office bath,entertainment area. the mechanical room is at the entertainment area. I want to know when i calculate free area sq. for sizing transfer grills for the mech rm. Do I calculate the whole basement or just the entertainment area as indoor free area ?
Thanks. Charlie |
dmcauley is a non-member guest and is in no way affiliated with InterNACHI or its members.
Does each room have doors? If so, then only the entertainment area. If not then entire basement. Might be a typo, but it is actually cubic feet you need, not square. Formula for combusiton air is h x w x l x 20 = amount of combustion air in the area.
I was taught that it was H x W x L x 3. That value must be greater than the combined BTU of all the gas appliances in the confined space.
The formula I was taught was from an appliance/HVAC class taught by Peoples Gas as they use this formula on CO calls, service work, etc.
Mark, the additional material is good info on how much combustion air is needed. |
Watch a CMI perform some calculations of confined spaces for hot water tanks and a gas-fired heating system, in a studio and on-site in a house. http://www.nachi.tv/ppv/8
Calculating confined spaces and combustion air is way beyond the scope; however, discovering safety, health, and fire hazards are not. After watching this video, an inspector should feel comfortable commenting upon confined spaces and using a narrative such as, "I have not made any calcuations relating to confined spaces and combustion air for the appliance; however, there may be a safety hazard here. We recommend having a professional inspect further and make any necessary corrections." |
rbrady is a non-member guest and is in no way affiliated with InterNACHI or its members.
Take a look at this to see how easy (NOT) it is to calculate combustion air requirements.
http://commerce.wi.gov/SBdocs/SB-UDC...yWorksheet.pdf Here is the one I was originally looking for: http://www.houseofcraig.net/combustion_air_calc.html |
Wow. That's great. Thanks.
When I was performing an Infrared Thermography Inspection in the IR video, I was concerned about how much power (cfm) the whole house fan had. I didn't want to suck in CO from fuel-fired appliances. I didn't know the cfm for the fan. |
WETT, Inc in Canada has a video of smoke being sucked out of the dedicated, directly connected combustion air duct (uninsulated metal) installed between wood floor joists, while in the firebox, the flame burns down into the firewood with combustion air being supplied by the chimney!! This was a situation where it was a WETT certified installer and a UL/ULC certified zero clearance "airtight" heating fireplace (read: stove in fireplace form). This was not a training setup but a real life installation!! Last edited by Brian A. MacNeish; 7/2/08 at 9:59 AM.. |
dbucknavich is a non-member guest and is in no way affiliated with InterNACHI or its members.
I think the most important aspect of this thread is to assure you do not spell combustion the way it is spelled in the thread title. Just a small observation on my part.
