Old 4/25/08, 7:37 PM
David C. Macy's Avatar
Default Damaged Paper to Insulation
What do you think caused the damage to the paper to the insulation?
There were numerous rodent baits & ant traps throughout the attic.
ID:	20662   damaged-paper-insulation-117108-028-small-.jpg.jpg
Old 4/25/08, 7:46 PM
Marc D. Shunk's Avatar
Banned
Default Re: Damaged Paper to Insulation
Looks like the insulation is installed backwards anyhow.
Old 4/25/08, 10:25 PM
Brian E. Kelly's Avatar
Rodents and ants.
Old 5/1/08, 11:32 PM
jkogel jkogel is offline
Does not look like the work of rodents to me, they chew and tear strips for nesting material. Ants don't eat paper, as far as I know. Maybe moths, caterpillars, or larvae of some kind?
Old 5/2/08, 2:47 PM
Jeffrey R. Pope's Avatar
Unless it was double sided, but that was my thought as well.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 5/2/08, 4:56 PM
Banned
A lot of earlier fiberglass and rockwool batts were double-sided with an asphalt based coating on the interior stapling flange side and simple thin brown paper to the outer side. Usually in this simple a situation, even if the vapour barrier were on the theoretically wrong upper side, no problems would occur unless you had an incredibly wet house below. In this case, many other problems would have shown up first.
Poly being applied to Basement walls dvalley Interior Inspections 40 11/24/09 10:49 PM
As promised - Review of Newman's second radon study Caoimhín P. Connell Ancillary Inspection Services & Additional Topics 2 1/26/07 8:05 PM
Vaulted Ceiling Insulation rcooke Canadian Inspectors 4 1/22/07 12:24 PM
New Old Insulation rcooke Canadian Inspectors 1 12/13/06 5:25 PM
