Inspected a house today built in 1991. In addition to dark spots at the drywall nails and/or screws in the ceiling, there were also dark outlines of the ceiling joists in many areas of the house. In other words, you could easily see where most of the joists were located because those areas were darker than the rest of the white ceiling.
The roof had ridge vents as well as soffit vents and there were no indications in the attic, on the sheathing or rafters, of any excessive moisture. Any ideas on what may have caused this? I've attached pictures, but they don't really show it well. Mark MD HI Lic # 30090 BPI Certified Building Analyst PA DEP Radon Cert # 2457 Certified Home Energy Tune-uP Inspector
Go to and read much information. http://www.google.ca/search?hl=en&q=...on+walls+&meta= ... Cookie Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
Thanks Roy and Brian, much appreciated!
Mark Mark MD HI Lic # 30090 BPI Certified Building Analyst PA DEP Radon Cert # 2457 Certified Home Energy Tune-uP Inspector
The tops of the joists may also be exposed above the level of insulation. Thus the joists become colder creating the ghosting. Candle soot and smoking and poor housekeeping may highlight the problem.
Additional insulation if required to cover the tops of the joists would be a good idea. |
I see this on an infrequent but regular basis. I saw it in a master bedroom last week. It was the only room in the house with candles on every flat surface. Ghosting it is.
This is often what it looks like thermally.
The difference in temperature across the ceiling causes a difference in molecular activity resulting in pollutants in the air to become statically charged and plate out on the ceiling. Last edited by dandersen; 12/9/09 at 12:24 PM.. |
| Asbestos ceiling tiles | scoslett | Interior Inspections | 30 | 10/20/07 2:30 PM |
| Joist Hangers at Cantilevered Rim | pdickerson | Exterior Inspections | 21 | 8/18/07 6:19 PM |
| Garage ceiling & door header | Al Barb | Interior Inspections | 7 | 3/27/07 12:07 PM |
| Frost, Ice, & Condensation @ RIM JOIST | Sean M. Jeric | Inspecting HVAC Systems | 4 | 2/5/07 6:56 PM |
| Vaulted Ceiling Insulation | rcooke | Canadian Inspectors | 4 | 1/22/07 12:24 PM |
