Sometimes it's the simple things that trip me up. When I entered the attic of a home with a wood shake roof, I could see multiple instances (5 or 6) of light coming through the shake. My gut reaction is that we should never see daylight through a roof, but there were so many and not a lot of moisture issues (some dry stains around some areas) it's making me wonder how to write it up. The exterior shakes were in fair condition, no immediate repairs required. Thoughts?
Tom Yeager Owner/Certified Inspector Inspect-It 1st 303-464-9090 www.tyeagerinspects.com NEHA Radon Certification # 104169 RT NACHI Certified Home Inspector |
| Find an InterNACHI certified Rhode Island Home Inspector (and anywhere else in North America) |
dbelmont is a non-member guest and is in no way affiliated with InterNACHI or its members.
I have found it is possible to see light on shake/shingle roofs. But usually when the shakes were warped and showing heavy sign of deterioration. What sort of condition were the shingles in?
I think you'd have to write up what you see. Hole and water stains. If they're not currently wet then say so and recommend monitoring. I find thermal imaging to work well in this circumstance unless it's been very dry and hot for several weeks. |
Hi to all,
we are getting way too used to thinking that all roof systems are designed to be air tight, when I lived in both the UK and New England it was very common to see points of light on older slate roofs. I would note that light could be seen between some shingles, but if I felt that there were no active leaks I would just advise monitoring the system (unless there were signs of damaged, rotting or warping shingles). Edit after 2nd thought: how old is the home/roofing system? all manufacturers of modern cedar shingle recommend a felt paper substrate over the skip sheathing, if this were a shake rather than a shingle it would require felt/tar paper between every course. Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 Last edited by gbeaumont; 6/13/09 at 5:14 PM.. |
Thank you both!
"Observe and report!" "Observe and report!" "Observe and report!" I will document what I saw and recommend monitoring. Older roof (15 years?) but in pretty good condition. Thanks! Tom Yeager Owner/Certified Inspector Inspect-It 1st 303-464-9090 www.tyeagerinspects.com NEHA Radon Certification # 104169 RT NACHI Certified Home Inspector |
That pic to me looks like a hole in the roof at a rafter, and I can't imagine it wouldn't be leaking. I agree with Gerry about shake and slate roofing in general, but in this case the hole looks like it's in the middle of a shingle/shake, and I'd have recommended repair.
Don't interfere with anything in the Constitution. That must be maintained, for it is the only safeguard of our liberties. Abraham Lincoln www.qualityhomeinspectionsfl.com |
| Building Science- research from respected sources | Brian A. MacNeish | Ancillary Inspection Services & Additional Topics | 17 | 7/12/11 6:31 AM |
| Ice Gaurd membrane | dmacy | Exterior Inspections | 36 | 6/14/07 12:21 AM |
| Roof Repair? Maybe NO | jhagarty | Exterior Inspections | 9 | 2/15/07 1:19 AM |
