Just some pics posted for discussion.. may help some someone.
Penetration Pics 1 and 2 Ok... There are 2 pics of PVC pipes penetrating the garage to house wall. What are the thoughts there? It's a whole-house vacuum.. but that doesn't really matter. Tile I took a picture of a *second floor* bathroom, where tile is installed directly over some basic t/g plywood. Carpet is actually *higher* than the tile. What's the concern? Hole Last one is self-explanatory...a hole in the duct. What would you say/recommend to your client? Home Inspections in Palmdale Lancaster California Tim Spargo Spec Rite Inspections Commercial and Residential Inspections Palmdale Lancaster Santa Clarita CA 661-317-5770 Last edited by tspargo; 6/15/11 at 7:34 PM.. Reason: learning to spell |
| Need a home inspection in Delaware? Check out InterNACHI's listing of Delaware certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Tiles and grout will start cracking in the first couple months.
Ducting may need to be replaced depending on the amount of damage and contamination on the inside so it will need to be disconnected and examined from end to end. Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
R302.5.3 Other penetrations. Penetrations through the separation required in Section R309.2 shall be protected as required by Section R302.11, Item 4.
4. At openings around vents, pipes, ducts, cables and wires at ceiling and floor level, with an approved material to resist the free passage of flame and products of combustion. The material filling this annular space shall not be required to meet the ASTM E 136 requirements. R302.6 Dwelling/garage fire separation. The garage shall be separated as required by Table R302.6. Openings in garage walls shall comply with Section R302.5. This provision does not apply to garage walls that are perpendicular to the adjacent dwelling unit wall. R302.5.2 Duct penetration. Ducts in the garage and ducts penetrating the walls or ceilings separating the Dwelling from the garage shall be constructed of a minimum No. 26 gage (0.48 mm) sheet steel or other approved material and shall have no openings into the garage. Carpet transition should have been used. ![]() Or something like this; ![]() The carpet should be cut in the center of the door so when door is closed neither flooring on other side of doorway will show. Check with your local dealer. Usually an annodized alluminum strip is intalled at the time of the ceramic tile installation for carpet transitions to carpet. ![]() Last, I think a nest of little varments is evident. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
I get "grief" for it, but I always call out plastic piping penetrating the garage firewall. I even had one the other day where the hot-water feed to the house was 3/4" PEX through a 2" hole in the firewall
You guys really have nothing better to write up do you..
I wish I could spend my days writing up plastic thorugh the drywall. I am too busy trying to dodge skunk turds in a water soaked crawlspace. Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
Problem is.. a lot of the inventory right now in southern california is flipped property.. and the home buyers think they are buying a re-vamped home. With a home warranty, no less. Typical Scenario A home was REO, then an investor (sometimes) spends as little as possible to "polish" it. You arrive and although it looks nice.. items like the tile installed directly to second floor 5/8" osb tg flooring will crack and so on. They are hoping that the thousands that they saved in renovations will be the buyers problem... "AS IS" Right? |
My PIA says I do not report on the condition of floor coverings. Sometimes I do anyway, but usually only for new homes. If I said anything, I'd just say it was an amateur installation and it would not be listed as a "significant" issue in my report.
For the duct, that small tear in the outer insulation is probably inconsequential as long as the inner duct is intact. (When you see something like that and turn your head real fast, it's like you never saw it all !) “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
I do not note the general *condition* of floors... and while I'm not perfect, if I spot or become aware of an installation defect that will reduce the flooring install service life to nill... I'll pass the info along. These re-vamped homes are giving the buyers the impression they are buying a substantially refurbished home.
As far as the hole in the duct... with the rodent droppings, the hole in the duct and the D-Con box next to it... it was too hard to "turn my head away real fast" Home Inspections in Palmdale Lancaster California Tim Spargo Spec Rite Inspections Commercial and Residential Inspections Palmdale Lancaster Santa Clarita CA 661-317-5770 Last edited by tspargo; 6/16/11 at 12:37 PM.. |
I didn't even notice the decon box. Just thought it was a tear. Probably a complete hole and should be reported. I agree completely.
What type of duct work is that, manufacturer?
Now I'm curious...why does it matter?
OK. I didn't see any holes. That was the issue posted.
| Same house CMU Cracks pics attached | gliebig | Structural Inspections | 5 | 3/29/07 4:39 PM |
| defect pics wanted | mnelson1 | Miscellaneous Discussion for Inspectors | 5 | 3/9/07 11:05 AM |
