Old 6/11/11, 6:26 PM
Sean Fogarty's Avatar
Default How do you test this?
Looked it up. GE hard wired made to function with the secruity system. NO test button anywhere. Is there a way to test this type of detector?
865-256-5397
www.moldandradon.com
www.thermal-inspection.net
Need a home inspection in New Mexico? Check out InterNACHI's listing of New Mexico certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 6/11/11, 6:33 PM
Stephen W. Stanczyk's Avatar
Default Re: How do you test this?
I don't test any smoke detectors when there is an alarm system present in the house. Sometimes they are monitored and fire is an automatic call for service unlike a window or door opening where the alarm company calls for verification first. I don't want to pay the $50 fine for a false alarm because the agent doesn't know the code.
Stephen Stanczyk
Old 6/11/11, 6:37 PM
I don't need to know what you don't do Steven, I want to know if anyone knows if these are testable. Obviously you are in the same boat im in.
Anyone else??
865-256-5397
Old 6/11/11, 6:44 PM
Roy D. Cooke, Sr's Avatar
Looks to me like heat detector The best way to test them is a 150 watt spot light they are I think various temp but usually 135° f will set them off . There should be a zoned control panel to tell what zone the fire is in .
Been 30+ years since I have had any thing to do with them... Roy
http://en.wikipedia.org/wiki/Heat_de...heat_detectors
Old 6/11/11, 7:02 PM
Sean, from what I could find, they have built in self-diagnostics when they are hooked up to a security system.
Most likely sends a trouble signal through the alarm panel when something is wrong. Similar to Commercial detectors. Panel shows a trouble light in the panel and calls it in as a trouble.
Description The ESL 500 Series self-diagnostic, two- and four-wire photoelectric smoke detectors are the industry's first conventional direct-wire smoke detectors with analog features such as drift compensation, multi-criteria detection and remote maintenance/trouble reporting (CleanMe). The 500 Series continually monitor their own sensitivity and operational status, and provide a visual indication if they drift out of the sensitivity range or fail internal diagnostics. The 521 Series also can send a signal (CleanMe) to any compatible control panel, allowing the dealer/installer to schedule a service call and avoid a false alarm. UL, ULC, CSFM Features and Benefits • CleanMe - remote maintenance reporting reduces false alarms (2-wire detectors only) • Smart dual fixed/rate of rise heats work with photo chamber to catch fires faster • Built-in drift compensation reduces false alarms • Field replaceable optical chamber makes servicing a snap • Small, low profile design blends in with any environment • See ESL Compatibility Index or call Sentrol Technical Support for panel compatibility
Old 6/11/11, 7:33 PM
Joseph Hagarty,  CMI's Avatar
Disconnect or tamper with it
when the Fire Company shows up...
you will know it works...
Joseph P. Hagarty
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 6/11/11, 8:10 PM
Joe Funderburk, CMI's Avatar
Hold a match up to it.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 6/11/11, 8:11 PM
Barry Adair's Avatar
for that man that can't "just say no"
stick incense is a nice addition
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 6/11/11, 8:36 PM
Thats what I found too marcel. The security system was not connected yet. I have never dealt with this type of detector so didnt want to miss something.
865-256-5397
Old 6/11/11, 8:37 PM
Thanks
865-256-5397
Old 6/11/11, 10:06 PM
Brian E. Kelly's Avatar
Like Barry said.
http://www.smarthome.com/manuals%5C7497r.pdf
Smoke Testing the Detector
Smoke detectors should be tested in place annually using smoke
or canned aerosol simulated smoke. Follow the instructions on
the canned smoke or use the following steps to test the detector
with smoke:
1. Hold a smoldering punk or cotton wick close to the smoke
entry openings.
2. Gently direct the smoke into the detector for 20 seconds or
until an alarm is indicated.
Be sure to extinguish the smoke source after testing! The
detector LED should stay on and an alarm should be indicated at
the control panel. Use the system reset switch to reset the
detector
Please post questions about anything having to do with roofing kshepard Exterior Inspections 165 6/17/09 11:47 AM
Moisture in slabs mcyr Structural Inspections 7 8/20/07 7:33 PM
bbbb mcyr Structural Inspections 1 8/19/07 10:26 PM
Inspection of HVAC by an area inspector. dmcauley Inspecting HVAC Systems 13 3/21/07 11:03 AM
