of the firebox, that is. . .
This seems to be a recurring theme for me lately. The form-boards used to build the masonry fireplaces have been left in at the breast plate. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
| Find an InterNACHI certified Wisconsin Home Inspector (and anywhere else in North America) |
Jeff, they must a figured since you burn wood in the fireplace it was all right. It will just burn off with the rest of the wood.
LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Apparently so
Jeff,
I'm not surprised at all. I've called out many fireplaces where wood was still installed up in the throat area. |
Dave, that is so when the creosote gets to heavy, the wood igintes it and cleans up the mess in the flue. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Then I should do the right thing and send my clients an addendum to my past findings.
Damn I'm glad I only see about two fireplaces per year. And usually two of those two are pre-fab. Just try to find a chimney sweep in SW FL!
Don't interfere with anything in the Constitution. That must be maintained, for it is the only safeguard of our liberties. Abraham Lincoln www.qualityhomeinspectionsfl.com |
| What's Inside A Chimney | mcyr | Inspecting HVAC Systems | 14 | 9/17/08 6:11 PM |
| Combustibles inside fireplace? | bmargiotti | General Inspection Discussion | 8 | 11/19/07 11:41 AM |
| Ground Wires Inside a Panel | mveitenhans | Electrical Inspections | 13 | 10/29/06 11:39 AM |
