rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
Does anyone have any comments about these things? Good/bad.indiferent/maint tips?
Thanks in advance |
| Find an InterNACHI certified Nevada Home Inspector (and anywhere else in North America) |
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father |
I saw that one too, doesn't really say much.
No it doesn't.
I have not sen the ACME unit. Just the ones that look similar to Radon mitigation fans but are rated for dryer vent boosting. Was the exhaust run long? He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father |
It seemed odd tha the assist fan was at a right angle pointing towards the dryer rather than towards the exterior. |
The paddle fan moves the dryer air. The other types are air over construction. He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father Last edited by mlarson; 8/13/09 at 11:06 AM.. Reason: spelling |
Thanks
Correct me if I'm wrong, but isn't the air flow (arrow) going the wrong way? Looks to be going towards the dryer, not the exterior.
Maybe Rick will tell us.
Sorry, still doesn't jive for me. Where is the dryer located? Above this unit, or in the basement? Where does the vent exit?
Replace plastic or foil, accordion-type ducting material with rigid or corrugated semi-rigid metal duct. Most manufacturers specify the use of a rigid or corrugated semi-rigid metal duct, which provides maximum airflow. The flexible plastic or foil type duct can more easily trap lint and is more susceptible to kinks or crushing, which can greatly reduce the airflow.
(looks like they are using the wrong vent material vertically.) I assume it goes to the roof and not the attic. |
What looks like foil material is tape (note the red markings). Let's see if my diagram uploads. Last edited by rmaday; 8/13/09 at 1:40 PM.. |
| Mr. Dryer Vent / Clean, Repair, Install | nhagarty | Ancillary Inspection Services & Additional Topics | 5 | 1/15/09 1:17 PM |
| Dryer Vent Repair Philadelphia | nhagarty | Ancillary Inspection Services & Additional Topics | 0 | 1/12/09 10:22 PM |
| Dryer Vent Repair Montgomery County | nhagarty | Ancillary Inspection Services & Additional Topics | 0 | 1/12/09 10:22 PM |
| Dryer Vent Repair Chester County | nhagarty | Ancillary Inspection Services & Additional Topics | 0 | 1/12/09 10:21 PM |
| Dryer Vent Cleaning Delaware County PA | nhagarty | Ancillary Inspection Services & Additional Topics | 0 | 1/11/09 1:22 PM |
