I did an inspection 3 days ago, and found this oddity. My first reaction was that this is all wrong. I told my client that I don't know if this is in violation of code or not, but that in my opinion, it could be a health/safety issue. We then joked about flipping over the door in the middle of the night and cartwheeling down the stairs. I haven't found anything that specifies whether the door into the basement needs to be a full length door or not. Can you help give me some clarity on this? I've attached a picture of the door.
Bobby Hamilton Bloodhound Home Inspection Services Youngstown Home Inspection Austintown Ohio Home Inspection Providing home inspections, state licensed termite inspections and radon testing in Youngstown, Boardman, Canfield, Poland, Howland, Warren and surrounding Northeast Ohio areas.
Bobby
Thanks for your insight on this. The door does not swing over the stairs, but it did strike me as odd. The door appears to have been cut in half, and my client wanted to make sure of the code issue on this. However, I'm not able to locate anything specific. Maybe someone else has an idea on this. Until then, I'll just put this under the "guess what I saw today" file, and tell her to replace the door if it is a concern. |
Robert,
Check this out www.askcodeman.com 1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 Radon Measurment Technician # R2279 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
I don't know of anything in the IRC that would deal with this issue.
I have one in my house (built in the 60's) just as Bobby described. There is a top and bottom to it and they pin together so that it works just like a normal door. It works well to keep the kids up stairs, but allows the cat to jump over it and go into the basement. As long as they operate properly I don't know why there would be any problems with them.
Richie Dimmerling II, P.E., S.I. Inspection Engineer 614.309.7552 |
As long as the 1/2 door heighth was 36" +- I don't see a problem with it.
Not on stairs but this home made Dutch Door had me lagging for a while.
I guess technically this would serve a a guard and should be a minimum of 36" tall to avoid trip hazard. Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
Have you ever tripped over a 34" wall ? |
Thanks everyone for all of your ideas on this one. It's nice to know that common sense still lives on in this world.
That's the minimum height for a guardrail. If I were a building inspector and had any problem with this, that's the only problem I can see.
| Commercial Electrical Inspections | jtedesco1 | Commercial Inspections | 29 | 1/12/08 5:03 AM |
| code for minimum floor space at top of stairs? | areid | Miscellaneous Discussion for Inspectors | 12 | 4/16/07 9:39 AM |
| Stairs required? | jmichalski | Interior Inspections | 21 | 3/5/06 4:47 PM |
| Massachusetts Board of Registration of Home Inspectors | jtedesco1 | Legislation, Licensing & Legal Issues for Inspectors | 0 | 2/14/06 3:38 AM |
