Any feedback on this one? Other than being sloppy work, does leaving the shingles on a roof deck that gets an addition framed on top (30 years ago) present a problem?
| Need a home inspection in Kentucky? Check out InterNACHI's listing of Kentucky certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
I would be concerned about the opening where the light is shining through .
galaxyhomeinspections.com An amateur built the Ark ! Professionals built the Titanic ! |
rarely done correctly
overframe of any roof best practice: requires the removal of existing shingles and installation of new frame in direct contact with preexisting roof deck also note the doubled plate for the rafter ends on the existing roof
I too often see 30 odd year old rood additions like the one depicted in the first photo. |
why not comp? ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
![]() Barry is correct, that is best practice of overframing. And debris from the stripping of the existing composition roof is usually taken down and left clean. That was an unaceptable execution of the work by the contractor, whether it was 30 years ago or now. Hell, I would have been fired 30 years ago to leave a mess like that. And Barry, when did it start snowing in your area for that picture? And what is that light at the end of the tunnel? LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Yes the light at the end of the tunnel.
I blew up the photo. That jackstud ( and God knows what it is resting on looks like it is wicking water at the bottom. Looks wet, saturated and stained. My PC?. Suspect: jackstud. roof opening in eaf,wooden shakes in new attic or addon and old roof covering. Recommend: licensed contractor remove all old shingles and install valor barrier, investage jackstud, repair opening in the eafe. Installing the rafters ontop of shingles will aloow for eventual movement and reseteling. The valley nails will posibly lift and problems can occure. montrealbuildinginspectionservice.com montreal-home-inspection-services.com home-inspections-montreal.com homeinspectionsservicesmontreal.com ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC. Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI) OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816 Last edited by ryoung7; 5/27/11 at 5:38 PM.. Reason: adding. |
It does not make sense to me that every shingle need to be removed. |
The minor sags/uneveness I have seen is from the original house framing not even being close to today's minimum codes......for example- hand hewn rafters in a ~200 year old post & beam that were 4' on center (the first house I owned and renovated.....the family I bought it from bought it back from me when I moved to Halifax area)........ and another i inspected a few miles up the road of the same vintage had roof rafters 6' on center but surpisingly stood quite straight and level. |
| Building Science- research from respected sources | Brian A. MacNeish | Ancillary Inspection Services & Additional Topics | 17 | 7/12/11 6:31 AM |
| Level of detail in the InterNACHI Roof Inspection Certification course/ advanced desi | kshepard | Roofing Inspections | 5 | 2/13/11 2:42 PM |
| Roof shingles for siding | belliott | Exterior Inspections | 18 | 8/5/09 11:23 PM |
| concrete roof tile over asphalt shingles | Scott Schultz | Exterior Inspections | 1 | 3/29/07 6:32 AM |
| Moss growing on roof | ecox1 | Exterior Inspections | 45 | 1/19/06 9:57 PM |
