You had to look closely at the aluminum perimeter strip separating glass panes to notice that these double-pane windows had an intermediate sheet of clear film installed to increase their thermal efficiency.
I don't know what causes film to fail but it's pretty easy to see the film when it does! Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
Nice view...in a wavey sort of way
Cheers Doug Cossar CMI, NHI Accurate Home Inspection Services Inc. Whitby Ontario www.accuratehomeinspections.ca 05021384 |
rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
Interesting... they are putting film in between the panes.. most manu. of IG units will Void your warranty for application of film to exterior of panes..
Can think of lot's of problems and bene's of such film. I've seen an IGU that had exploded from application of tint/film on interior side of IGU.. side # 4 (depending on Manu.) heat built up between panes...POP!! Milgard was gonna fix it anyway.. how nice, the customer didn't know not to tint the window Tim |
Thanks Brian,
Just looked up some of the Heat Mirror info. Learn something new everyday! Still a bit sided myself as to adding films on existing IGU's. The Heat Mirror internal film was something I hadn't run accross. Tim |
It really is pretty invisible unless it does whatever this one did.
| Energy Audit Article | ebadofsky | General Inspection Discussion | 1 | 2/2/07 7:04 AM |
