Old 6/5/07, 1:06 AM
kmcmahon kmcmahon is offline
Please Note: kmcmahon is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Failed under testing
Well, it finally happened to me. Testing a new overhead door/opener.
1st tested the photo sensors...no problems.
I don't use an object other than the pressure of my hand to test the resistance auto-reverse.
Stuck my hand under and applied a little pressure...door kept going down. I let go and it was coming down and as I was approaching the button I noticed the door stop...but the opener kept going....before I could hit the button..CRUNCH!!
Homeowner came back and I immediately explained what happened. He said he installed it and said he had problems with it tracking right from the start....I could see he was not thrilled, but he said "well, it is what it is" nothing you could have done. He took responsibility for it...whew! Anyway, that was a first for me and it totally sucked seeing it happen.
Old 6/5/07, 1:16 AM
David A. Andersen's Avatar
Default Re: Failed under testing
We are required by state law to test the reverse operation of all garage doors!
I wonder how many broken doors we have had the past year?!
Old 6/5/07, 7:08 AM
Joseph Hagarty,  CMI's Avatar
From the photo, I can see that the operater reinforcement bar and door strut are missing.
http://www.clopaydoor.com/publicfile...for-Opener.pdf
An improperly installed (incomplete installation) door operator should not be tested as testing will generally result in what you have experienced.
Manufacturer also will not provide warranty coverage for improperly installed doors / operaters.
Joseph P. Hagarty, CMI
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 6/5/07, 12:08 PM
cbrands's Avatar
cbrands cbrands is offline
Please Note: cbrands is a non-member guest and is in no way affiliated with InterNACHI or its members.
i had a similar situation a few days ago.
but when i did it, the lag screws holding the track in place came out of the wall.
no stud behind the drywall.
no one will ever be happy when an inspector does something like this, even if it's not your fault, but think of the unhappy client months down the road if this was not discovered.
Old 6/5/07, 10:22 PM
Quite true!
I have had over a dozen doors break under testing this year.
The door installation could not pass the testing procedure. Never had an owner complain, but I'm sure it will happen soon. I have the state licence board number to refer them to. I had that lag bolt issue several times! New construction. Just can't seem to hit that header!
We have more that just a few children hurt from garage doors every year. What's a loose bolt?!
Old 6/6/07, 9:27 PM
Sale of the home didn't go thru as my clients backed out based on my report. Sellers realtor called...want's me to pay for the damage.
Old 6/6/07, 10:13 PM
I'd tell the Realtor thanks for the offer but no.
If the homeowner/installer had problems with it from the start he should have told you...it failed while testing.
Larry Kage, CMI
231 929 3525
Old 6/7/07, 12:23 AM
William J. Decker's Avatar
G-d helps drunks, little children and NACHI inspectors
Glad to hear it went well.
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Old 6/7/07, 4:05 AM
In my area our RE Contract gives the buyer the right to inspect anything BUT if anything gets broken - its the buyer or his inspectors responsibility to pay for fixing it.
Old 6/7/07, 8:56 AM
Homeowner installation not properly conducted, failed during testing.
Who are you going to find to put it back together WRONG?
Old 6/8/07, 6:20 PM
wsiegel wsiegel is offline
"In my area our RE Contract gives the buyer the right to inspect anything BUT if anything gets broken - its the buyer or his inspectors responsibility to pay for fixing it."
I believe that the contracts state that the home must be left in the same condition that it was found in. But there is a big difference in 'if anything gets broken' and 'failed under test".
Old 6/17/07, 2:35 AM
Not really in the seller or agents eyes. Its still the HI broke it.
Old 6/17/07, 9:49 AM
When the installation is visibly deficient, the door should not be tested.
The Door Operator should be reported as "Not Inspected" noting the deficiency present along with a recommendation that testing be performed after the repairs are made by qualified contractors.
Phone: 610-399-3675
Old 6/17/07, 11:11 AM
Keith Swift, PhD. Keith Swift, PhD. is offline
After breaking a door opener and paying for it, to say nothing of spending the better part of a day at a house, I stopped pressure-testing openers. Instead, I state that the opener is not equipped with an infra-red auto-reversing mechanism, which I recommend as a desirable safety feature. After I made that decision, my anxiety level in garages has gone down to zero.
InterNACHI Vice President, InterNACHI Editor-in-Chief, co-founder CalNACHI
Old 6/18/07, 1:04 AM
dcook1's Avatar
dcook1 dcook1 is offline
Please Note: dcook1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Kevin,
What is status now? I would probably pay for it and chaulk it up to experience. Never test something that looks wrong! State why in your report! If the client backs out, at least you do not have to pay for the repair.
Currently I am waiting on a client backing out of one but I had marked the problem. The seller called me it later and freaked on me as he tried it and it broke. I stated that is why I did not test it. Now he has a home to sell and fix. I have nothing to fix.
What am I waiting for? The purchaser said he is looking at another house and would call me this week as "It was the best $350 he ever spent." The quote will be in my website by end of week
Moisture in slabs mcyr Structural Inspections 7 8/20/07 8:33 PM
bbbb mcyr Structural Inspections 1 8/19/07 11:26 PM
Classes/ Education for Mold bwieczorek Miscellaneous Discussion for Inspectors 6 9/10/06 3:01 AM
Arizona, one day mold cert dbucknavich General Inspection Discussion 4 6/26/06 10:32 PM
