Old 1/29/08, 4:40 PM
sspradling sspradling is offline
Please Note: sspradling is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Felt on the underside of roof sheathing
Anyone ever heard of doing this? The entire attic of this condo had felt paper on the underneath side of the roof sheathing. Any thoughts would be appreciated.
Stu
Old 1/29/08, 4:42 PM
Doug Edwards's Avatar
Default Re: Felt on the underside of roof sheathing
I have some thoughts on it but I don't think they are going to helpful. Ive never seen this done before, and my thoughts are not going to be fit for general consumption.
Old 1/29/08, 4:57 PM
I knocked (############ the underside with a hammer handle, but I didn't stick holes to probe. No staining on the trusses, or rust on the gussets. No ventilation is an issue here as well, but I can write that up, I'm just locked up on the felt thing.. The roof was solid to walk on, nice and smooth. Any suggestions on how to write this up?
Stu
Old 1/29/08, 5:04 PM
iniquette's Avatar
iniquette iniquette is offline
Send a message via ICQ to iniquette
Could you tell if there was also felt between sheathing and shingles?
Ian Niquette
Square One Home Inspection
Markesan WI 53946
www.squareonehomeinspection.com
Active Rain Network
INACHI Awards Portal
Want To Exchange Links?
What we've got here is......failure......to communicate.....
Old 1/29/08, 5:07 PM
iniquette's Avatar
I have seen this in my former line of work. Usually by a DIY trying to compensate for a lack of ventilation and poor insulation. Usually doesn't end up well. Locks alot of moisture in, but the insulation doesn't get as wet then, right?
Ian Niquette
Markesan WI 53946
Active Rain Network
Old 1/29/08, 5:09 PM
Never seen it, wierd. Curious to the find now.
Marcel
Old 1/29/08, 5:19 PM
Ian,
Yes, there was felt underneath the shingles.
Oh, I wish I could figure out the photo posting thing..
Stu
Old 1/29/08, 5:24 PM
Michael Larson's Avatar
Originally Posted by sspradling
Ian,
Stu
Stu, do this tutorial and let me know if you have any trouble.
Old 1/29/08, 5:48 PM
Barry Adair's Avatar
what kind of shingle wood, comp, tile....
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 1/29/08, 6:05 PM
Banned
How so? or what is their reasoning?
Please explain.
Old 1/29/08, 6:07 PM
Comp shingles, Barry.
Old 1/29/08, 6:45 PM
iniquette's Avatar
Brian,
I have seen this twice. Both times the attic was very poorly vented and had a lot of moisure in it. Both times it was explained to me by the home owner that they were told this would keep the sheathing dry. And if any water did happen to accumulate it would not trickle onto the insulation. That is just what I was given as reason when I saw this. Both had very bad looking shingles on the roof by the way.
Ian Niquette
Markesan WI 53946
Active Rain Network
Old 1/29/08, 6:53 PM
Since they installed felt under the sheathing worried about drips, I would be curious to find out how long a nail they used to nail the shingles, especially if it was only 1/2" sheathing.
Wow.
Sounds like a story that might blow away. ha. ha.
Marcel
Old 1/29/08, 6:57 PM
James F. McKee's Avatar
I just want to know how they managed to put felt under the sheeting ????
Old 1/29/08, 7:49 PM
iniquette's Avatar
In both case I saw, it was cut in between the joists and stapled to each one. Just senseless to me. But that's just my opinion.
Ian Niquette
Markesan WI 53946
Active Rain Network
Building Science- research from respected sources Brian A. MacNeish Ancillary Inspection Services & Additional Topics 17 7/12/11 6:31 AM
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior Inspections 6 10/13/07 8:10 AM
Roof Repair? Maybe NO jhagarty Exterior Inspections 9 2/15/07 1:19 AM
Frost on Underside of Roof Sheathing scosta Interior Inspections 14 2/26/06 11:00 PM
