Old 10/8/08, 1:48 PM
lfoster's Avatar
lfoster lfoster is offline
Default Fiber mat insulation, cathedral ceiling
Looked at some classroom type buildings for a church yesterday. The buildings were built in the 60's.
They had low slope roofs of 2:12. The roofs were standing metal seam or tar and gravel.
On the interior, they had cathedral ceilings with an exposed fiber / grass mat insulation visible from the room interiors. This fiber mat covered the under structure of the roof and extended to the eaves / fascia. Part of the original installation.
I haven't seen this type material before and need to find out what it is. what it's called, pro's or con's.
Any known problems - other than it droops and falls when the roof leaks !!
I will defer to roofer, but need information for myself.
Any thoughts are welcome.
Thanks in advance,
Old 10/8/08, 3:11 PM
Bobby Hamilton's Avatar
Bobby Hamilton Bobby Hamilton is offline
Default Re: Fiber mat insulation, cathedral ceiling
Ran into this product about 4 years ago when I was doing some work for another contractor. The only thing I can remember about it was that we were told that it was fireproof. And it is, because we tried to light it and it didn't burn.
Bobby Hamilton
Bloodhound Home Inspection Services
Youngstown Home Inspection
Austintown Ohio Home Inspection
Providing home inspections, state licensed termite inspections and radon testing in Youngstown, Boardman, Canfield, Poland, Howland, Warren and surrounding Northeast Ohio areas.
Old 10/8/08, 4:29 PM
rradavich rradavich is offline
Please Note: rradavich is a non-member guest and is in no way affiliated with InterNACHI or its members.
They are Tectum Panels. Google Tectum panels
Old 10/10/08, 9:47 PM
lfoster's Avatar
Thank you,,,,
Old 10/11/08, 8:08 PM
scorcoran scorcoran is offline
In case others wanna get some quick info on this I've copied and pasted from Tectum.com:
Whether you require wall panels, ceiling panels, or an acoustical roof deck, Tectum Inc. has the right product for your noise problem. Our reputation for acoustical solutions in the commercial and institutional construction industries is well respected. With over 50 years experience in reducing noise worldwide, Tectum Inc. specializes in acoustic panels that are both abuse and impact resistant.
Easy to work with and install, Tectum panels and systems are cost effective and require little maintenance. They are available in natural, white or custom-painted finishes, and are field-paintable up to six times.
Tectum products are cementitious wood fiber acoustical panels composed of aspen wood fibers. All of our products carry a Class A/1 interior finish rating for flame and smoke. In addition, all Tectum products are "green" because they are manufactured using only renewable wood and other sustainable raw materials.
Old 10/11/08, 8:17 PM
You are correct Sir.
Used that product many of times in the 70's.
It's uses was for roof decking and sound panels.
I used to call it Shredded Wheat panels, for when it got wet it would resemble the cereal. ha. ha.
Fire rated and good product for its time when dry.
Marcel
Building Science- research from respected sources Brian A. MacNeish Ancillary Inspection Services & Additional Topics 17 7/12/11 6:31 AM
Poly being applied to Basement walls dvalley Interior Inspections 40 11/24/09 10:49 PM
Question about exposed styrofoam insulation. mlong Exterior Inspections 9 12/21/07 8:33 AM
Vaulted Ceiling Insulation rcooke Canadian Inspectors 4 1/22/07 12:24 PM
New Old Insulation rcooke Canadian Inspectors 1 12/13/06 5:25 PM
