Old 1/20/07, 6:50 PM
Rafael Rafael is offline
Please Note: Rafael is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default fire door
hi i need to know if anyone can tell me how to adj the interrior door
hinge on a garage door which leads from garage to interior. i need to adj because of not eneogh tension how do you take the out from the door
Old 1/20/07, 6:55 PM
Roy D. Cooke, Sr's Avatar
Default Re: fire door
Some times the easiest way is to remove a hinge and add one with a spring in it .
Roy Cooke
Old 1/20/07, 9:27 PM
Ted Allen Ted Allen is offline
There is a screw type fitting in the top of the hinge. It needs to be tweeked.
Old 1/21/07, 7:40 AM
tschwalbe's Avatar
tschwalbe tschwalbe is offline
You need a special little tool that comes with the hinge then you turn the little piece at the top of the hinge with the holes in it. be careful because there is a little stud or pin that will fall out and you will never find it again. This little stud is what keeps tension on the spring. If the door is over 10 years old buy new hinges because the springs become sprung with time. If it were my door i would go to home depot & buy a automatic door closer that way you can adjust how fast & how strong the door closes. good luck
Old 1/21/07, 12:34 PM
ckratzer ckratzer is offline
Please Note: ckratzer is a non-member guest and is in no way affiliated with InterNACHI or its members.
Bingo!
And the special little tool is an allen wrench.
Old 1/21/07, 1:09 PM
Originally Posted by ckratzer
Bingo!
That is correct, and you want to be careful when you engage the Allen wrench and take tension off, the little pin will become loose and when you pull it out you install it in the next hole available. This will increase the tension. Continue this process until the door closes properly.
Marcel
</IMG></IMG>
Old 1/21/07, 1:21 PM
Marcel,
Are you following me?
You're making me nervous
Cheremie
Old 1/21/07, 3:15 PM
Marcel,
Cheremie
Coincidence my dear Watson. You just are one step ahead of me. I am slow today I guess. ha. ha.
Marcel
</IMG></IMG></IMG></IMG></IMG>
Old 1/24/07, 6:29 PM
Thanks to all , i got it
Escape, Fire & Smoke Alarms badair Interior Inspections 14 1/28/08 7:21 AM
Service door Fire Rating jmichael Interior Inspections 2 8/13/07 10:45 PM
