Go Back   InterNACHI Message Board > Specific Inspection Topics > Interior
Interior Contains discussions about the interior portion of a home inspection. This includes stairs, walls, floors, ceilings, smoke detectors, et cetera.
Old 3/27/07, 12:50 PM
Timothy R. Smith Timothy R. Smith is offline
Default fireplace flue
We inspected a house that has a 4" pvc flue attached to a prefabricated propane burning fireplace. the gas valve was inside the firebox, can anyone tell me if this is right / wrong - I called a propane dealer and he said it could be correct - but still a PVC flue????
Old 3/27/07, 1:12 PM
rcooke rcooke is offline
Banned for Violating COE
Please Note: rcooke is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: fireplace flue
Go to the manufacture and see what they say.
Roy Cooke
Old 3/28/07, 10:46 AM
Tim
I've seen DUMB...but this just about takes the cake.
Old 3/28/07, 11:11 AM
David A. Andersen's Avatar
Gas valve is OK. But I still don't like it. You could have a run-a-way appliance and not be able to shut it down.
Now, PVC flue, No Way.
Old 3/28/07, 8:42 PM
Helpfull information;
http://www.vangasfireplaces.com/files/comp.html
Marcel
Cyr Home and Commercial Property Inspections
IAC2 Certified
NACHI04070211
http://co.nachi.org/inachiawards
Commercial Builder
CertainTeed
Master Shingle Applicator
Shingle Technology
Ouellet Associaties Inc.
http://www.oaconstruction.com/
Old 3/28/07, 8:54 PM
William E. Siegel William E. Siegel is offline
I believe that you will find that the gas stack has to extend at least 2 feet above the roof.
Old 3/28/07, 10:11 PM
phinsperger's Avatar
Marcel,It is helpful information, however much of it is for wood burning units. Not Gas. It would appear that Vancouver Gas also sells wood units and did not make it clear on that page that it refers to wood units.
Old 3/28/07, 11:17 PM
Definately higher than it is...depending on pitch of roof.
Larry Kage
231 929 3525
Professional Inspector and Infrared Thermographer serving the Traverse City, Michigan area and beyond.
ITC/FLIR CERTIFIED BUILDING SCIENCES THERMOGRAPHER
ITC/FLIR CERTIFIED LEVEL 1 THERMOGRAPHER
Old 4/1/07, 12:18 PM
John J. Passailaigue, Jr.'s Avatar
John J. Passailaigue, Jr. John J. Passailaigue, Jr. is offline
Send a message via AIM to jpassailaigue
It looks like a plumbing vent stack with a cover on it! I would be throwing a fit if I could talk to the home builder and the "three blind mice" referred to as code enforcers. You can not convince me that PVC piping can be used as a flue for fire place. If the homeowner decides he wants a wood burning instead of a gas........you may seriously be in trouble later on. BTW- GOOD CATCH! Way to use your eyes and brain! You are making the inspection industry look good. Good work. Was this a new home?
John J. Passailaigue Jr.
NACHI05062580
Auburn Home Inspection
Auburn, Alabama
WAR EAGLE!
Old 4/1/07, 5:40 PM
homebild homebild is offline
Both propane and natural gas burning appliances routinely use PVC pipe as a vent.
High efficiency appliances do not need any other type of vent in many cases.
Power vents are almost always constructed of PVC pipe.
Don't see anything particularly wrong here....even with the height above the roofline.
Propane manufacturers have their own set of rules that do not necessarily need to meet Fuel Gas Codes for vent height.
Check the manufacturer's installation instructions.
Old 4/2/07, 9:15 PM
Let's start with this, that can be life saving for some somewheres.
http://www.wellspropane.net/safety.shtml
http://www.csia.org/homeowners/gasapp.html
http://www.heat-fab.com/products/saftvent_desc.shtml
http://www.propane.ca/cleantruth/res...al/venting.asp
Both propane and natural gas burning appliances routinely use PVC pipe as a vent. Not true
True
Power vents are almost always constructed of PVC pipe.Not true
Don't see anything particularly wrong here....even with the height above the roofline.Height of vent through roof holds true as it would for a regular chimney.
Propane manufacturers have their own set of rules that do not necessarily need to meet Fuel Gas Codes for vent height. Read again.
Check the manufacturer's installation instructions.10-4
Equipment, material, or services included in a list published by an organization that is acceptable to the AHJ and concerned with evaluation of products or service, and whose listing states that either the equipment, material, or service meets appropriate design standards and been tested and suitable for a specified purpose.
Hope this clairifies a few things.
Marcel
IAC2 Certified
NACHI04070211
Commercial Builder
CertainTeed
Shingle Technology
Old 4/3/07, 1:02 PM
rwand1 rwand1 is offline
I believe PVC is rated for upto 60 degrees celcius. I have never seen a propane or natural gas vented with PVC, always metal.
Old 4/3/07, 1:45 PM
This may be of interest, see the first article.
http://www.tssa.org/CorpLibrary/Arti...2E1A0A9470C293
Old 4/5/07, 1:41 AM
Pfffft....
Power vented high efficiency furnaces or boilers rarely require anything BUT PVC for vents.
This is one such inspection item that needs to be defered to the local mechanical code inspection agency for verification and the manufacturer's installation instructions before writing it off as a 'bad installation'.
All the more if you have no experience as a mechanical contractor or mechanical codes inspector.
Old 4/5/07, 8:13 AM
My comment should have read..." I have never seen a propane or natural gas "fireplace" vented with PVC, always metal."
Must be a regional thingy.
The Rumford Fireplace: Safety vs. Efficiency mbryan Interior 2 4/28/08 5:38 PM
Cracked flue tile bknowlton HVAC 6 2/2/07 12:37 AM
Flue Size when size matters? msylvester HVAC 14 1/21/07 12:29 AM
Gas Log Flue venting height. lagudo HVAC 34 4/7/06 2:42 AM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
