Old 4/11/11, 12:46 PM
Mark S. Tyson Mark S. Tyson is offline
Default Fireplace Insert
Saturdays inspection had a manufactured wood burning fireplace insert. All of the units that I'm familiar with require a minimum 1" clearance from combustibles and I reported as such. This unit has a 1" x 4" piece of dimensional lumber installed on either side of the fire box. We don't have a lot of fireplaces here in South Florida but i have never seen this before nor can I think of a reasonable reason for lumber to be there. I would guess that it has been installed after market but for what other than starting a fire. Part of a shipping crate that should have been removed in 1992 when the insert was installed? Any Thoughts?
fireplace-insert-mary-rose-dietrich-041.jpg   fireplace-insert-mary-rose-dietrich-045.jpg
Mark S. Tyson
M Tyson construction LLC
Tyson Home Inspections
Certified General Contractor #1516843
Florida Licensed Home Inspector #1824
Member N.A.C.H.I.
IAC2 certified
Member Florida Building Officials Association
http://www.TysonHomeInspections.com
Need a home inspection in Virginia? Check out InterNACHI's listing of Virginia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/11/11, 12:53 PM
Jeffrey R. Pope's Avatar
Default Re: Fireplace Insert
Doesn't look right to me. There are "zero-clearance" units, but the front of the firebox usually requires non-combustible materials. The only way to know for sure is to check the manufacturers specifications.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 4/11/11, 1:09 PM
Jeffrey R. Jonas's Avatar
Almost looks as if the wrong size insert was installed, and someone (Harry?) installed the wood to 'close the gap'.
Anyway I look at it, combustable materials in that location are just a bad idea.
Old 4/11/11, 7:08 PM
agallatin agallatin is offline
It sure enough doesn't fit the space ! The whole thing looks pretty amateur . I'd recommend a certified wood burning fireplace inspector ! LOL on this one !
galaxyhomeinspections.com
An amateur built the Ark !
Professionals built the Titanic !
Old 4/12/11, 1:33 AM
Now that I'm looking at it on my home monitor, I can tell you for certain - this is an improper installation.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 4/12/11, 3:04 AM
Tom Leahy Tom Leahy is offline
It's like the panels are for a smaller fireplace so they just decided to fill in the gaps, with WOOD. Move to defect award category!!
Fort Worth Home Inspector
Dallas Home Inspector
Old 4/12/11, 7:41 AM
Barry Adair's Avatar
also apparent is improper draft evidenced by the soot on the masonry under the mantle
DISCONTINUE USE until installation of the unit & flue are fully evaluated, repaired and approved by a person qualified by the AHJ
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 4/13/11, 8:09 AM
Larry J. Michael Larry J. Michael is offline
Sometimes the best finds are when something just don't look right and that don't look right!
Greensboro Home Inspection
Providing home inspections in Greensboro, High Point, Burlington and the surrounding areas.
greensboro-home-inspection.html
Raleigh Home Inspection
Home inspections in Raleigh, Durham, Cary, Chapel Hill, Apex and surrounding areas.
Raleigh-home-inspection.html
BassRumors.com
Providing a blog, news, and forum dedicated to bass fishing.
Fireplace insert question? rwills Inspecting HVAC Systems 6 3/10/11 3:30 PM
Gas Insert fireplace Recommendation dvalley Interior Inspections 7 2/12/09 11:21 AM
Hearth size??? jcampbell Inspecting HVAC Systems 32 6/1/08 1:56 PM
Difficult Chimneys thance Inspecting HVAC Systems 2 1/29/08 8:16 PM
