Garage has two metal combustion air intakes for a prefab fireplace penetrating the garage firewall separation. Would you call this out? It could pull exhaust fumes from the garage into the living space.....yet it would be in the fireplace and vented out the chimney.....
"He is no fool who gives what he cannot keep to gain that which he cannot lose." Jim Elliot 1949 Gerald Wilcox Harvey, ND CMIA, RMT www.housecheckhomeinspections.com www.homeinspectorinnorthdakota.com 701.324.4075 Minot, ND Home Inspections Devil's Lake, ND Home Inspections Bismarck, ND Home Inspections Jamestown, ND Home Inspections Home Inspector in North Dakota North Dakota Home Inspection |
| Find an InterNACHI certified Idaho Home Inspector (and anywhere else in North America) |
I don't know if this helps.
R1006.2 Exterior air intake. The exterior air intake shall be capable of supplying all combustion air from the exterior of the dwelling or from spaces within the dwelling ventilated with outside air such as non-mechanically ventilated crawl or attic spaces. The exterior air intake shall not be located within the garage or basement of the dwelling nor shall the air intake be located at an elevation higher than the firebox. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Thanks guys.
| Firewall penetration | gwilcox | Exterior Inspections | 5 | 9/20/09 9:43 AM |
| Garage Firewall? | slemarr | Interior Inspections | 3 | 5/1/09 10:13 PM |
| Can crawl through condo attic firewall? (Pics) | Brian T. Harris | Interior Inspections | 4 | 12/17/08 3:24 AM |
| Garage Firewall | jfunderburk | Structural Inspections | 19 | 4/9/06 8:23 PM |
