Old 2/8/12, 1:04 AM
Default First time I've come across this....
This is on a 30 year old home...
1st pic is from the inside...fixed panel on right, sliding door on left.
2nd pic is from outside view...fixed panel on left, sliding door on right.
This is an entry way into the master bedroom.
Jeff
first-time-ive-come-across-img_0148.jpg   first-time-ive-come-across-img_0149.jpg
Jeff Wicklander
Corwick Home Services
Join my business on Facebook
Need a home inspection in Alabama? Check out InterNACHI's listing of Alabama certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/8/12, 1:18 AM
Stephen W. Stanczyk's Avatar
Default Re: First time I've come across this....
Amazing that after all these years someone figured out it was installed inside/out..... I wonder how they put the stick in the door......
Stephen Stanczyk
Old 2/8/12, 1:30 AM
Bob Elliott's Avatar
I feel your pain.
Easy to miss ,so good catch.first-time-ive-come-across-exterior-slider-door.jpg
The lock was busted on mine(from this summer)
Old 2/8/12, 2:14 AM
Cameron C. Anderson Cameron C. Anderson is online now
Incredibly, I found that 5 or 6 times last year alone. Prior to that maybe twice in eight years. You would think the screen door would tip the people off who live in these houses.
Cameron Anderson
Bachelor of Architecture, U of I, Urbana IL
Illinois Licensed Inspector
www.aaintegrityhomeinspection.com
Old 2/8/12, 10:23 AM
Joseph Hagarty,  CMI's Avatar
The door is properly installed as many manufacturer's use this design.
Pella Door is one of them. (operable panel exterior, screen interior)
http://www.pella.com/doors/explore-d...spx?StyleID=11
Joseph P. Hagarty
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 2/8/12, 10:47 AM
Gary D. Rowden Gary D. Rowden is offline
I agree with Joseph, this is factory design, even though I believe it’s is a very poor design. I have personally installed this type of slider before in the past, and it had me scratching my head on my first install, “What were they thinking”.
Old 2/8/12, 10:58 AM
Tim Spargo's Avatar
When I see the active panel on the outside... I'll try to discern if there are weeps or other indications of the orientation of the frame.. most of the time as guys have said above, it's simply the way they are made.
Having said that... I can't say I've run across a screen on the interior of a slider too many times, a window, yes.. but a slider? I'd look at the frame to see, as mentioned how it drains water etc.
Tim Spargo
Spec Rite Inspections
661-317-5770
Old 2/8/12, 12:11 PM
An HI An HI is offline
Please Note: An HI is a non-member guest and is in no way affiliated with InterNACHI or its members.
In our wind-blown northern Atlantic coast locale, I have inspected Pella wood windows that were 30+ years old and in good to great condition. This company has been manufacturing top-of line wooden windows for many years- I believe they know what they are doing.
If I could afford the Pella brand, it would be my choice in wooden windows.
Old 2/8/12, 12:56 PM
I suggest you not dismiss this posting as my example was a way in if you lifted the door and pulled out the bottom.
Jeff has a 90 degree angle stop however mine did not even have that.
Pointing this out as a security risk in a metropolitan area is a good idea.
Old 2/8/12, 1:25 PM
A Pella door (if properly installed and locked) can not be lifted and pulled out at the bottom.
If you are able to do that (with a Pella door), the installation is defective and not the fault of the manufacturer of the door.
Joseph P. Hagarty
Phone: 610-399-3675
Old 2/8/12, 1:45 PM
OK ,great but please emphasize it is that type (only) designed that way as many new guys might overlook actual issues such as mine had.
If I can lift it out and get inside it is an issue no matter what.
Old 2/8/12, 1:53 PM
The initial posting was that the door was installed backwards.
It is important to understand the features and designs of all doors so that proper recommendations can be made.
If the door was a Pella, and was reported as backwardly installed, the Inspector is going to look foolish which will call into question all of his reported observations.
Joseph P. Hagarty
Phone: 610-399-3675
Old 2/8/12, 2:19 PM
Joe , what are the details in the design of a Pella that prevent the door from being lifted off the track?
All I see is that little angle stop.
Old 2/8/12, 2:30 PM
Bob,
The locking mechanism (in addition to the bracket and tracking) prevents lifting the door.
That works in full open and ventilating feature.
and if the door is unlocked, no need to lift it...
just slide it open....
Joseph P. Hagarty
Phone: 610-399-3675
Old 2/8/12, 2:48 PM
Bob,
I hope it is a good lock.
Actually I kinda laugh when I see double deadbolts on many rear doors that have glass panels as the burglar can just smash the glass and reach in to turn the key however as we know locks are there to keep honest people honest. LOL
Sad is that many use a double cylinder which is actually against code as a work around.
I call that out.
Canadian Equipment Inspectors Needed! Quiktrak Inc Canadian Inspectors 19 2/7/08 5:15 PM
