Old 1/20/09, 12:22 PM
Scott A. Hand's Avatar
Scott A. Hand Scott A. Hand is offline
Default Frost in attic
This is my first full winter inspecting. The attic I just inspected has a buildup of frost on the plywood and the nails pertruding through have ice on the tips. The frost is sparatic around the sheathing as some areas have no frost. Is this something that would be normal in the winter when the temps are below freezing? It indicates moisture in the attic to me, and that isn't a good thing.
It's a very small attic with a Hip roof and ventilation appears adequate.
Thanks
Old 1/20/09, 12:28 PM
Jeffrey S. Campbell's Avatar
Jeffrey S. Campbell Jeffrey S. Campbell is offline
Send a message via AIM to jcampbell Send a message via MSN to jcampbell Send a message via Yahoo to jcampbell
Default Re: Frost in attic
hows the insulation... inadequate insulation allowing heat to leak up through will cause condensation and freezing/frost... I see this often in the areas of the scuttles/access where the heat leaks up through...
Jeff Campbell
Campbell Property Inspections
http://www.maineshomeinspector.com
Pittston, Maine
NACHI04013010
Old 1/20/09, 12:46 PM
iniquette's Avatar
iniquette iniquette is offline
Send a message via ICQ to iniquette
I would agree, insulation is probably not adequate, or the ventilation really is not adequate, thus allowing the frost and condensation. Your right Scott, there will be moisture up there when it melts and starts dripping. Look for older signs, like staining or look for signs of insulation that was once wet. Also, find out if there has been any recent work in this area, as this could be a new problem as a result of this work.
Ian Niquette
Square One Home Inspection
Markesan WI 53946
www.squareonehomeinspection.com
Active Rain Network
INACHI Awards Portal
Want To Exchange Links?
What we've got here is......failure......to communicate.....
Old 1/20/09, 2:41 PM
Here is one photo of what's in there. There is a brand new shiny chimney flue on the roof and through the attic. Could the black be from an old or new chimney leak? Looks like certain smoke damage. And if so, how come it is only on the plywood and not the rafters?
What would be the best way to report this?
Thanks
Old 1/20/09, 2:46 PM
my guess would be an ongoing moisture problem... perhaps bath vent exhausting into attic?? but there could be a fungi issue going on as well... I saw something similar a few months ago and it came back positive for a type of mold... cannot tell without testing. definately more evaluation/testing needed.
Jeff Campbell
Pittston, Maine
NACHI04013010
Old 1/20/09, 3:23 PM
All the white stuff IS frost. This was my second time in ther in two days and my first time there was no frost. The heat in the home was turned up a few degrees while we were there for an hour and 1/2, and now there is frost. So if the ventilation appears addequate, the insulation is probably the problem, right?
Should I recommend the client get an energy audit done to determine where the heat is getting into the attic from. Also recommend evaluation by an insulation company to see what the best alternative is.
Recommend chimney contractor evaluate fireplace and chimney for any leaks before operating fireplace.
Thanks
Old 1/20/09, 3:44 PM
Peter Doane's Avatar
Scott,.. Just Note the obvious... "Signs of / history of trapped moisture content in the attic" Current frost condition, water stains, and delamination of the roof decking material. A condition of, or a lack of proper ventilation, insulation or the combination of the two. Recommend a qualified roofing contractor review further for determination and corrective repairs.
Peter Doane
NACHI ID# 05120681
I was not referring to the white stuff (frost) as mold... rather the other darker material.
Jeff Campbell
Pittston, Maine
NACHI04013010
Old 1/20/09, 3:58 PM
I'm sorry...I didn't mean to assume you meant that about the frost. I was just pointing out that it was definately frost.
Thanks for your replies. I appreciate the help.
Old 1/20/09, 4:19 PM
jkogel jkogel is offline
Just a comment -- the rafters do indeed have some of the dark staining at their junction with the sheathing. It has a smokey look and the chimney was just replaced, there's moisture now, possibly mold stain, "Further evaluation is called for."
John Kogel
www.allsafehome.ca
Old 1/21/09, 9:55 PM
Russell Spriggs's Avatar
Russell Spriggs Russell Spriggs is offline
Originally Posted by jcampbell View Post
my guess would be an ongoing moisture problem... perhaps bath vent exhausting into attic?? .
Exactly what we found today, along with only 4" insulation, none over hatch, and minimal ventilation!
1907 house.
Old 1/21/09, 11:05 PM
Vince Santos's Avatar
Vince Santos Vince Santos is offline
The last time I saw this there was a plumbing line break in the home with a good amount of flooding. Was there any evidence of recent water damage in the home like a flooded basement?
Vince Santos
StepByStep Home Services LC
(734) 748-9584
Providing Home Inspection Services to Southeast Michigan
facebook
ITA Trained and Certified
Old 1/21/09, 11:22 PM
Nope. No flooded basement.
Old 1/22/09, 12:31 AM
Keith Runquist, CMI Keith Runquist, CMI is offline
Send a message via AIM to krunquist
If the black stuff is mold it indicates long term moisture. I'd guess there is no vapor barrier in the attic. If the black stuff is soot then the chimney or old chimney is suspect. Your job in either case is to report what you see and suggest proper evaluation by the proper trade. It's intersting but I wouldn't get too bent out of shape trying to figure it out. Report and defer.
Old 1/22/09, 4:56 AM
mlehman mlehman is offline
Please Note: mlehman is a non-member guest and is in no way affiliated with InterNACHI or its members.
Scott, I seen this alot last week. If the home is not venting properly the moisture will build up in the attic. With the cold temps we had last week there was frost on nails, and anywhere humidty couldnt escape. One thing to do is take a moisture mete in the attic and check the sheathing for moisture levels.
The first pic looks like past fire damage.
Mold question? ccurrins Interior Inspections 35 1/23/09 12:55 PM
Heavy frost in attic mashburn Interior Inspections 19 12/30/07 9:40 PM
Frost in attic mashburn Structural Inspections 12 1/29/07 6:18 AM
