Old 4/10/07, 2:05 PM
Homewood Homewood is offline
Please Note: Homewood is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Garage door
Two questions:
1. I know garage door springs require safety cables but do the single over the door torsion springs for garage doors require safety cables as well.
2. What is maximum height for the photo-electric devices. I called one out as too high. That one must have been at least 3' high. When checking these devices out, it was nice to have the real estate do her can-can dance.
Old 4/10/07, 2:15 PM
Default Re: Garage door
#1 Check with manufacturer--it depends on the age and type of equipment. Some of the older ones required safety cables--newer ones don't.
#2 4" to 8" -- varies with AHJ.
3' is a bit much, though...
Old 4/10/07, 2:18 PM
Usually the torsion bar acts as a retainer.
If your AHJ won't answer about the height, refer to the manufacturers instructions.
Abraham Lincoln
Old 4/10/07, 6:10 PM
Brian E. Kelly's Avatar
http://www.dasma.com/safetygdopeners.asp
The Six-Inch Rule. The photo eyes mentioned above should not be installed higher than six inches above the garage floor. If the eyes are installed higher, a person or pet could get under the beam and not be detected by the photo eyes.
Old 4/10/07, 6:51 PM
Brian;
Those were good safety tips that we can not advertize enough to protect the general HomeOwner and protect the little ones.
Good posts.
Marcel
Old 4/10/07, 11:09 PM
sturetsky sturetsky is offline
I agree with Blaine, the torsion bar in the "over the door" torsion springs will act as a retainer should the spring break.
Automatic garage door openers..what are concerns? lfreeze Structural Inspections 8 5/18/07 10:38 AM
Garage ceiling & door header Al Barb Interior Inspections 7 3/27/07 12:07 PM
Garage Door Safety...No Reverse...Advice Please gliebig Exterior Inspections 33 3/17/07 7:28 PM
Hollow core door off garage kblair1 Interior Inspections 22 12/3/06 6:39 PM
