Is this set up an approved method for an opener installation? Unable to locate any info from the manufacturer.
Andrew MacDonald MacDonaldPropertyInspections.com InsightThermalDiagnostics.com ITC/FLIR Certified Building Science Thermographer ITC/FLIR Certified Level 1 Thermographer |
Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
I have found installation like that very problematic especially when testing the automatic reverse function as it can tweek the door.
www.mauihomeinspections.com |
I would hate to see what happens should the cable come off the left side drum with the door on the way up.
The torque of the closer would and failure of the left pulley would make the top panels derail and guess what? Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Thanks Dale,
Helpful as always. Just the info I was looking for. Mark and Marcel, I agree totally. It was disclaimed in my report. Thank you. Andrew MacDonald MacDonaldPropertyInspections.com InsightThermalDiagnostics.com ITC/FLIR Certified Building Science Thermographer ITC/FLIR Certified Level 1 Thermographer |
Dale,
This thing went up and down perfectly. I expected to see some torque, but did not. Thanks for the link, manufacturer is quite clear on the right or left of center location. Andrew MacDonald MacDonaldPropertyInspections.com InsightThermalDiagnostics.com ITC/FLIR Certified Building Science Thermographer ITC/FLIR Certified Level 1 Thermographer |
I guess it's OK, unless I'm reading this incorrectly
You can fasten the header bracket within 4 feet approximately 1/2" (1 cm).(1.22 m) of the left or right of the door center only if a torsion spring or center bearing plate is in the way; or you can attach it to the ceiling (see page 9) when clearance is minimal. It may be mounted on the wall upside down if necessary, to gain |
Did anyone ever see a Miracle Garage Door Opener? They are designed to be mounted on the side - motor mounts on the door. I think it a miracle if they operate at all.
In the world view we are all important and our mere existence effects all life. Jack Gilleland Home Inspection Services Clayton Commercial, Multifamily, and Residential jgilleland1@att.net Ohio_Commercial and_Home_Inspections activerain |
Thanks Mike. The last one I saw (2 weeks ago) went up about 3" higher on the motor side. Suggested that an installation co. be called to adjust. Wheels seem to be spitting off rubber like a bad retread.
Jack shaft is the only way to go
http://www.1stdooropeners.com/jackshaft.htm 1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 Radon Measurment Technician # R2279 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
John,
I should have been more clear on the description of the door...it's a 16 ft. door. So, we are out of compliance with the manufactures' installation instructions of 4ft. left or right of the center line. Just thought I would clarify. Andrew MacDonald MacDonaldPropertyInspections.com InsightThermalDiagnostics.com ITC/FLIR Certified Building Science Thermographer ITC/FLIR Certified Level 1 Thermographer |
Bruce, didn't know liftmaster made one like that, sure looks better than "It's a miracle if it opens" brand.
| Possibly Overloaded Garage Door Header | pdickerson | Structural Inspections | 25 | 8/3/08 2:26 AM |
| Evaporative cooler in garage | chellickson | Inspecting HVAC Systems | 9 | 7/23/07 12:08 AM |
| Garage ceiling & door header | Al Barb | Interior Inspections | 7 | 3/27/07 12:07 PM |
| Garage Door Safety...No Reverse...Advice Please | gliebig | Exterior Inspections | 33 | 3/17/07 7:28 PM |
| Garage fire rated wall | jlybolt | Interior Inspections | 3 | 6/18/06 6:21 PM |
