Old 6/18/06, 3:31 PM
jlybolt jlybolt is offline
Please Note: jlybolt is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Garage fire rated wall
New home inspection -
Wanted to see others opinions. Electric furnace and water heater in same closet. The closet can be accessed at garage wall and from within the home at the furnace side. The closet goes all the way thru. Basically if both doors were open you could see the interior of the home from the garage side or vise versa. See pictures. The door at the garage appears to be made of plywood. Door at furnace side appears to be solid. I dont like the installation.
Should there be a fire rated wall seperating the garage from home? (Between the furnace/water heater)?
Plywood door on the garage side meet min. fire code?
garage-fire-rated-wall-060618-01-020.jpg   garage-fire-rated-wall-060618-01-021.jpg   garage-fire-rated-wall-060618-01-022.jpg
Old 6/18/06, 3:34 PM
pdacey's Avatar
pdacey pdacey is offline
Please Note: pdacey is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Garage fire rated wall
As long as one of those doors is fire rated, I wouldn't have a problem with it. It would be the same situation as the door from the living space that leads into the garage.
Old 6/18/06, 4:07 PM
Jeffrey R. Pope's Avatar
Self-closing would also be a requirement if it were in CA.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 6/18/06, 6:21 PM
Thanks guys. Buyer said he was going to install wall regardless.
Fire Rated Garage Door? jfunderburk Interior Inspections 3 7/21/07 10:01 AM
Fire wall between garage and attic ltreesh Structural Inspections 12 5/4/06 9:44 PM
