Old 6/19/09, 8:26 AM
Tim Larsen Tim Larsen is offline
Default garage firewalls - lack of
Howdy,
A lot of older houses with garages in the basements don't have firewalls/ceilings. In fact they are usually just open framing. Maybe not so common in the North where I am moving, but very common here in the South.
Is it a "reasonable" recommendation (obviously a good idea) to bring it up to modern standards and sheet rock (fire rated) the ceilings and walls to interior spaces?
That could get pretty expensive for a 3 car garage...
TIA,
Tim
Find an InterNACHI certified South Dakota Home Inspector (and anywhere else in North America)
Old 6/19/09, 10:42 AM
James H. Bushart's Avatar
Default Re: garage firewalls - lack of
yes.
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
Old 6/19/09, 10:49 AM
rmaday's Avatar
rmaday rmaday is offline
Please Note: rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
If that's the case ,better your client understand before they close escrow than after.
Old 6/19/09, 12:49 PM
Joe Funderburk, CMI's Avatar
I don't think it's a reasonable thing to do, but I recommend it in my reports nonetheless. I always tell my clients that the best defense against fire is a working smoke alarm.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 6/19/09, 12:57 PM
rmaday's Avatar
I'd prefer a fire extinguisher for defense.
Old 6/19/09, 2:50 PM
Nick Gromicko's Avatar
Drywall is very inexpensive, and you don't have to finish it to perfection for a garage.
Find a Home Inspector
Old 6/19/09, 5:51 PM
Great, thanks for the input.
Cheers,
Tim
Old 6/22/09, 10:28 PM
Gregory A. Liebig's Avatar
Gregory A. Liebig Gregory A. Liebig is offline
I note in my reports whenever I see the following in Garages...
  1. Open gaps (larger than the thickness of a dime) that is not backed with at least 3/4" plywood or a stud
  2. Skuttle holes that are not properly sealed (using the same criteria) or have vertical doors that are not self-closing
  3. Ceilings that are not at least 5/8" thick sheetrock or if the ceiling is open framed there is not a continuous wall that separates the garage from the dwelling space continuing to the roof line.
  4. Walls adjacent to the dwelling space that are not coverd with sheetrock
  5. Any ventialtion penetrations into the attached garage especially if there are not back-draft dampers
I hope this helps!
Greg Liebig, Owner
Sheboygan Wisconsin Home Inspector
4-Square Home Inspections, LLC
Where Knowledge will put your Mind at Ease ©
Sheboygan, WI 53081
(920) 451-4646
www.sheboyganhomeinspector.com
www.4squarehi.com
Like Us on Facebook
Follow Us on Linked-In
Old 6/23/09, 7:55 AM
Michael Roberson's Avatar
Michael Roberson Michael Roberson is offline
In my previous occupation, I have hung and finished hundreds of firewalls. the only one that didn't pass in inspection is when an electrician cut a 6x6 in chunk out to run his wire. Pass on to your client, that if they ever want to properly finish the garage drywall, to tell their contractor they want a good job. I have seen so may fire tapes that were so bad, I had to remove the tape and refinish it, it is commonplace to "slap it up quick Joe, its just a fire tape"
Hope this helped someone.
Old 6/29/09, 1:32 PM
Along those same lines - how can you ID fire rated sheet rock without a visible label? What about tape?
Tim
Old 6/29/09, 8:39 PM
Tim
I don't. If it's 5/8 thic type X then that satisfies the one-sided application (ceilings). If it's 1/2 thick then that satisfies the two-sided application. Sometimes you can see some ID if there is a scuttle in the garage with no insulation. Tape isn't necessary if the gap in the seams does not exceed 0.01" (about the thickness of a US dime) or it's backed by solid wood or other drywall material as long as the joints are staggered.
Greg Liebig, Owner
Sheboygan, WI 53081
(920) 451-4646
www.4squarehi.com
Like Us on Facebook
Garage / Apt separation Carol Jones Structural Inspections 1 6/14/09 7:56 AM
Evaporative cooler in garage chellickson Inspecting HVAC Systems 9 7/23/07 12:08 AM
Garage ceiling & door header Al Barb Interior Inspections 7 3/27/07 12:07 PM
Garage Door Safety...No Reverse...Advice Please gliebig Exterior Inspections 33 3/17/07 7:28 PM
Garage fire rated wall jlybolt Interior Inspections 3 6/18/06 6:21 PM
