What is with the Styrofoam wedges at the vehicle doors?
Are they for keeping the insulation panels in place? Or are there parts missing for the panel supports? Seems like there would be clips for this. |
| Find an InterNACHI certified Tennessee Home Inspector (and anywhere else in North America) |
Looks like they bought a non-insulated door and are trying to keep the panels from rattling around.
Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
While many garage doors have a core, there are still plenty that are single layer that have no core; often older, less expensive units. I have seen doors in Northern climates where foam or EPS (expanded polystyrene form) has been added to add some R-value (~R-4 / inch). The quality of the foam will determine it resistivity to heat flow, of course. If foam is used, it is equally important the edges are sealed as well..just like in a home, gaps quickly defeat the purpose.
Jeff Tatlock BEACHSIDE Home Inspection www.beachsideinspection.com/request_more_info |
Up here exposed foam is not allowed in a garage.
| Garage door inspection procedure | bgromicko | General Inspection Discussion | 5 | 8/7/09 12:47 PM |
| New article on garage doors and openers | inxil | InterNACHI & RealMatcher Blogs | 0 | 7/10/09 11:20 AM |
| Military Frequency Jams Garage Doors | jmckenna1 | Miscellaneous Discussion for Inspectors | 0 | 12/3/06 1:18 AM |
