What is this? Next to a direct vent natural gas fireplace.
Thanks in advance. |
| Need a home inspection in Wisconsin? Check out InterNACHI's listing of Wisconsin certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Looks like a Model DH-1537 Dohickey Thingy.....I think??
BPI Certified Professional Building Analyst BPI Certified Envelope Professional Infraspection Institute Certified Level II Thermographer # 8510 www.dapkusinspections.com www.chicagoinfraredthermalimaging.com www.mychicagohomeinspector.com www.commercialbuildinginspectionchicago.com Professional Infrared Network Chicago Energy Audit Aerial Infrared Inspection Certified Infrared Thermal Imaging |
Appears to be a variable speed switch for the blower motor???? my guess
Is it a sensor for a remote control option?
774 Manor Road Staten Island, NY 10314 718-514-3393 |
That was my best educated guess. Not sure what the black toggle slide switch is at the bottom, though.
How about a speed control so the fan can be slowed .
Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
Are you certain it is related to the gas fireplace?
I have seen similar controls for ceiling fans. I saw one mounted such as yours, and also thought it was for the gas fireplace. Fortunately, the homeowner was present and he stated it was for a ceiling fan that had been removed. Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
I'm not certain about anything with it, hence the post. Just an assumption, because it was next to the fireplace.
What's its purpose? |
looks like switched photoelectric sensor
test using electrical tape to block out the light and see what it controls, may have to "monkey" (proven inspector technique taught by Jim McKee) with the switch also or antenna outlet ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
Did you ask the seller??
It's the call button for the maid to come turn your fireplace on.
https://www.facebook.com/StateCollegeHomeInspector http://www.centreinspection.com Centre Inspection Services proudly serves the following towns; State College, PA 16801, Bellefonte, PA 16823, Centre Hall, PA 16828, Spring Mills, PA 16875, Millheim, PA 16854, Boalsburg, PA and the surrounding areas. |
| Fireplace clean and scan | dmacy | Interior Inspections | 4 | 11/21/10 8:16 PM |
| Hearth size??? | jcampbell | Inspecting HVAC Systems | 32 | 6/1/08 1:56 PM |
| The Rumford Fireplace: Safety vs. Efficiency | mbryan | Interior Inspections | 2 | 4/28/08 4:38 PM |
| Difficult Chimneys | thance | Inspecting HVAC Systems | 2 | 1/29/08 8:16 PM |
