What are the requirments for a gas log insert.
The fireplace was masonry with a damper. There was no glass doors. The manufactures instructions stated that it needs to be vented to the exterior. If the damper is open it is vented. The owner has not been using the fireplace. I told her to have a fireplace specialist examine before she sells her home Thanks for any information. |
A damper-stopper or spacer must be installed to prevent the damper from being closed.
Some dampers may also have a knockout.
Dampers are always removed on gas log fireplaces in my area.
A damper clip should be installed that keeps it open 24/7 in case of a gas leak.
Richard W. Washington, owner RW Home Inspections, Inc. www.RWHOMEINSPECTIONS.com Texas Real Estate Commission (TREC) Professional Inspector License #7238 Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter InterNACHI member since 2004 Based in Katy, serving Houston and all surrounding communities |
Just because there are gas logs in the fireplace doesn't mean that the new buyer will retain them. Inspect it as a normal masonary fireplace.
Regarding the logs themselves, I usually say, "According to today's standards, manufactured fireplace clearances are determined by the manufacturer. The buyer should consult the manufacturer's manual or otherwise contact the manufacture to determine if the clearances are adequate. Gas cutoffs are acceptable inside a gas fireplace firebox, if the manufacturer approves it. Consult the manufacturer's operator's manual prior to operation of gas logs." I often add, "Consistent with our inspection agreement, the gas logs were not tested. You should have the homeowner/builder demonstrate the operation of the gas logs and transfer any operating manuals to you." “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
On what basis did you refer the fireplace to a specialist?
| Gas log insert damper | lbrown2 | Inspecting HVAC Systems | 11 | 9/18/08 7:07 AM |
| Wallboard behind shower insert | mgault | Plumbing Inspections | 15 | 10/24/07 9:27 PM |
| Fireplace-metal insert to metal flue connection | sfalvey | Interior Inspections | 5 | 10/31/06 12:25 AM |
